Spring Installed Height
How close does Spring Installed Height have to be to spec? I just don't want to go buy a micrometer for it--even though i will probably end up buying one. I am thinking of measuring a peice of something with a caliper that measure to .001 slide that in and shim till i get it to that height--what do you think?
The valve tips are going to be worn down...so how much shimming am i looking at?
Re: Spring Installed Height
I guess summit sells one for like $40 so maybe i'll just get me one
http://store.summitracing.com/defaul...=egnsearch.asp
This Com Cams one looks nice too--has bigger range too
Take the springs to a place that can check the spring pressure. The installed hgt., is just one facet of spring install.
what kind of springs you running? are heads on or off the car??
usually whqat you do is get it as close to the middle as i can....what i mean by this is that if the say that you need to install springs in the range of 1.750 to 1.550 then ill do 1.650 .
help any???
help any???
I'm just using LT4 springs. Heads on the car.
How much will they charge though......it's so easy to do---if it's going to be 100 bucks than i rather just buy a spring pressure checker for 75bucks--everything costs soo much just to have them push the spring down--since I will be using it later i'm sure
I midas well just go buy me one. Anything is better than my 130,000 mile springs......It doesn't have to be that close--since it's the stock cam...not like i'm needing the extra pressure really anyway.
Where would i get shims to change height if it's off?
I midas well just go buy me one. Anything is better than my 130,000 mile springs......It doesn't have to be that close--since it's the stock cam...not like i'm needing the extra pressure really anyway.Where would i get shims to change height if it's off?
Originally Posted by White Knight
How much will they charge though......Where would i get shims to change height if it's off?
Carogna'sZ-28
Feb 3, 2015 07:04 PM
GA93FORMULA
Jul 24, 2002 11:38 PM
