Spohn TA and LPE DS
Old Apr 7, 2003 | 08:29 AM
94blkTA's Avatar
Spohn TA and LPE DS
Does anyone here run an spohn ta with the 3.5 lpe ds? Do you have any clearance issues with the ds safty loop? In the process of installing the ta, it's the older style, I notice the safty loop wasn't going to clear the ds without the full wieght of the car being support by the rearend.
Old Apr 7, 2003 | 08:35 AM
Gripenfelter's Avatar
If there's that little clearance I'd be careful going over bumps.
Old Apr 7, 2003 | 08:51 AM
94blkTA's Avatar
I actually took out the lpe ds for the time being, I thought i would see it anyone else had problems with it.
Old Apr 7, 2003 | 10:05 AM
IROCZZ3's Avatar
This is on my 3rd gen IROC but it's pretty much the same....
I'm running the newer style TA with an LPE driveshaft and have no clearance problems. It's close but it doesn't touch. If you have a lowered car, you might have some problems. There are a couple of 3rd gen guys that have driveshaft interference with the Spohn loop and they're using stock driveshafts.
Old Apr 7, 2003 | 10:21 AM
I have a pic of my "original design" Spohn TA, with DS loop around a 3.8" ACPT heavy duty CF DS, and it's tight, but it didn't hit. Not sure how the "original design" (the one with the "slider") compares to the current design.... the one with the link in place of the slider. I've got the current design, and it's very roomy with a 3" chrome moly DS.
SPOHN TA/ACPT DS
Old Apr 7, 2003 | 10:32 AM
LPEdave's Avatar
Depending on where it's hitting, you could use some washers as shims between the two halves of the DS loop, to give you some more room up top. I've done that on mine, with a 3.5" DS.
Dave
Old Apr 7, 2003 | 10:39 AM
94blkTA's Avatar
Did you have any problems when putting your up on jackstands or anything that would remove the weight from the rearend and let it drop. While installing mine I had it up on jackstands and when I tried to install the front mount for the ta the safty loop hit the driveshaft about 1/2" to 1" from the mounting brackets. I may try and jack the car back up and leave full weight on the rearend and take some measurements on clearance with the stock ds that put back in the car to see if the lpe will fit with acceptable clearance. I'll just have to try and remember to unblot the ds before putting it on jackstands again.
Old Apr 7, 2003 | 10:45 AM
LPEdave's Avatar
Me, no...
Dave
G-BODYT56
Jan 14, 2022 11:14 PM
RUENUF
Mar 13, 2016 03:37 PM
Henson071
Dec 30, 2015 09:55 PM
96SilverRam
May 28, 2015 02:09 AM
