Speed Inc's Cadillac cam
Old Jul 4, 2007 | 06:03 PM
  #16
thesoundandthefury's Avatar
Originally Posted by INTMD8
Well, what do you guys want to know specifically?
Can you grind this cam so that the same valve lifts are achieved with 1.5 ratio rockers as they are with 1.6's?
Old Jul 4, 2007 | 06:25 PM
  #17
95ttoplt1's Avatar
You can't grind any cam that will give you the same lift at the valve with a different rocker ratio.
Lobe lift x rocker ratio = valve lift.
If you change the rocker ratio you will change the lift at the valve.
Old Jul 4, 2007 | 06:58 PM
  #18
Why?
Old Jul 4, 2007 | 07:03 PM
  #19
95ttoplt1's Avatar
Valve lift is a product of lobe lift multiplied by the rocker ratio.
To keep valve lift the same with a different ratio rocker you would need a different lobe lift.
Just an example:
lobe lift .350x 1.5rocker ratio= .525 valve lift
same lobe x1.6 rocker ratio= .560 valve lift
to have the same lift with the 1.5 but using a 1.6 rocker you would need to reduce lobe lift to 328.125(.525/1.6). 328.125 x 1.6 = 525
Make sense??
Old Jul 4, 2007 | 07:07 PM
  #20
I understand all that, and that's what I'm asking him: if he can grind the lobes with enough lift to achieve the same (with 1.6's) valve lift with 1.5's.
Old Jul 4, 2007 | 07:23 PM
  #21
Rebs's Avatar
It's a cam I designed to work with stock components while retaining stock idle and driveability and I think it works rather well in that application.
With ported lt1 heads and mid length headers will the idle still sound the same as stock? Also are ported heads worth it on this cam? Thanks
Rebs
Old Jul 4, 2007 | 09:04 PM
  #22
INTMD8's Avatar
From: I reached back like a pimp and smacked that LS1....
From what I remember we installed that cam in another car that had headers and it was still undetectable.
And I do think ported heads would be worth doing, they would gain you power even with a stock cam.
I do not think the cam could be ground to achieve the same lift with 1.5's as it currently does with 1.6's.
Old Jul 4, 2007 | 11:08 PM
  #23
My Iroc Z28's Avatar
Rebs
Yes, even opening a cutout on the exhaust made it louder but no hint of a cam being there at all. It's pretty impressive because some folks still don't believe it has a cam in it. Makes it harder to sell the car advertising a "Cammed" LT1 when it sounds stock.
Old Jul 6, 2007 | 12:00 AM
  #24
Rebs's Avatar
What springs do you recommend?
rideordie
Nov 5, 2019 04:52 PM
ChrisFrez
Jan 4, 2015 08:43 AM
mark0006
Dec 25, 2014 09:50 PM
NewsBot
Dec 3, 2014 12:30 PM
Queens94z28
Nov 20, 2014 06:03 PM
