Specs on Stock LT1 Heads (Valve Size and CC)
Old May 11, 2008 | 05:19 PM
ENRKyle20's Avatar
Title says it all. I am gettin ready for a LT1 Buildup and I want to crunch some numbers on Desktop Dyno.
Also. I notice the compression ratio is not the same on a LT1 in a 97 camaro vs 97 firebird TA. Is that a type on KBB or is one 10.1 and the other 10.0?.. if so why? they have the same hp and tq arccording to KBB?
Old May 11, 2008 | 06:23 PM
Zigroid's Avatar
1.94" / 1.5" valves
my combustion chambers were 53.8cc and 53.4cc (different for each side)
stock compression is supposed to be 10.4:1. it varies from car to car as tolerances don't always line up exactly but most LT1s will be at that if not very close to it.
Old May 11, 2008 | 06:37 PM
ENRKyle20's Avatar
why are they diffrent from side to side?
thanks for the info
Old May 11, 2008 | 07:07 PM
The Engineer's Avatar
thanks for the info
Assembly line mass-production! Which is typical for a production engine.
WD
Old May 11, 2008 | 07:12 PM
marshall93z's Avatar
Originally Posted by Zigroid
1.94" / 1.5" valves
+1
Old May 12, 2008 | 12:17 PM
ENRKyle20's Avatar
ok. Very good.
I have a few more questions on the stock stuff of a LT1
Stock Cam Lift, Duration, overlap, and lobe center?
Type of lifter (hyd. roller I would think?)
also, it wants to know about the intake.. CFM. i dont know how to measure thats when there is no carb.
thanks
Old May 12, 2008 | 10:52 PM
LT1/LT4 head flow info.... old, but still valid:
http://www.malcams.com/legacy/misc/headflow.htm
General 4th Gen info - again, old but still useful:
http://www.ws6.com/faq/
Killer94z
Jan 13, 2015 12:06 PM
birdblack
Dec 30, 2014 06:59 PM
1LEThumper
Jul 14, 2003 12:45 PM
MJ_Z28
Aug 8, 2002 09:07 PM
Brian-94TA
Jul 31, 2002 02:52 PM
