Spark plug choice for AFR heads
Old Apr 15, 2008 | 07:47 AM
chris96ta's Avatar
Im looking for a spark plug reccomendation for my setup. I have an lt1 383 stroker. AFR 210cc heads. From the searching i have done i've found that i need a gasketed plug? I would like to stick with ngk as im currently running the tr6 plug in my stock motor and have to great success. The new motor is built for boost. 8.5:1 cr. I will be turbocharging next year but i am going to run it na this year. Thanks in advance.
Old Apr 15, 2008 | 10:20 AM
https://www.camaroz28.com/forums/sho...d.php?t=431689
Old Apr 15, 2008 | 10:23 AM
DAVE00's Avatar
Stick with the NGK's as they are the best in LT-1's. Here is a link to what AFR recc's and make sure to go with one that is 1-2 heat range due to the blown setup. FYI - I have splitfires in mine with AFR 190's (older style) and never had a problem. Would like to go with NGK's but to much of a PITA to change and not worth it for me. Good luck.
http://airflowresearch.com/sbc_faq.php#sparkplugs
Old Apr 16, 2008 | 11:16 AM
chris96ta's Avatar
Thanks for the replies. I think i'm going to try out the NGK #7942.
Old Apr 16, 2008 | 12:21 PM
WS Sick's Avatar
I use the Autolite AR50 in my car. I like how they have a shortened and rounded strap. when I had them on my 355 with pretty well stock compression I used the Autolite AR3910. I like the cheaper autolites, they work fine for me.
parkers Z28
Mar 11, 2016 08:14 PM
mritter1965
Feb 9, 2015 07:01 PM
MadMav
Feb 6, 2015 11:02 PM
Jazsun
Dec 29, 2014 12:14 PM
