Throttle Body Question
Old Apr 15, 2008 | 09:09 PM
camarostripe96's Avatar
From: Academy,tx (Home to Temple/Academy Drag Strip)
ok i have a 1996 Trans am with Lt1, borla cat back, k&n cold air intake, longtube headers,ory, short throw 6 speed, and i was wondering if u can get a bigger throttle body with just those mods? if so how much bigger without having to do anything else? 52mm? 58mm? i am just curious about getting a bigger throttle and what are the gains with one?
Old Apr 15, 2008 | 09:24 PM
19z28camaro02's Avatar
With your mods, you do not REQUIRE a bigger throttle body, but.....you asked a question, and you shall have the answer. The front of your intake plenum, what the throttle body feeds, is 52MM. So you can go to a 52MM Throttle body without much other modification.
Old Apr 16, 2008 | 04:19 AM
red1984's Avatar
If you plan on going with a bigger cam and ported heads in the future it would be a good investment, if not the way your car is set up right know you wont see much of a gain. Have you done any work to the suspention? Drivetrain? You might want to consider investing money there.
Old Apr 16, 2008 | 06:50 AM
well i thought about going with gears next but we will see!!!
Old Apr 16, 2008 | 07:22 AM
2000GTP's Avatar
Better idea, do the gears versus the throttle body.
Old Apr 16, 2008 | 07:40 AM
ok but what should i get ? 3.73? 4.10? whats the difference in them? also would i have to get my speedometer calibrated
Old Apr 16, 2008 | 08:36 AM
2000GTP's Avatar
Either choice of gear would work well with your six speed, most opt for the 4.10s though. You will have to have the PCM tuned in order to correct the speedometer calibration.
Old Apr 16, 2008 | 08:54 AM
ss.slp.ls1's Avatar
Get the 4.10's, you'll thank yourself.
Old Apr 16, 2008 | 10:03 AM
oh ok , well how much will the speedometer be off with 4.10's?and why would i thank my self for them?
Old Apr 16, 2008 | 10:56 AM
You'll have better 60' times, quicker acceleration, but don't forget your gearbox here. You can't get on the torque converter and put pressure on the rear end with an M6, so everytime you launch, your rear end goes from dead stop to a ~4,500 RPM launch.
Old Apr 16, 2008 | 11:17 AM
ss.slp.ls1's Avatar
^^^ Are you trying to say that 4.10's are not good with an A4 with a big stall?
Old Apr 16, 2008 | 11:19 AM
what do u mean?
Old Apr 16, 2008 | 11:23 AM
30AnniversaryZ28's Avatar
what do u mean?
He's saying that 4.10s in a m6 is a lot more stressful on the rear on versus an a4 with 4.10s, since automatics preload.
Old Apr 16, 2008 | 11:37 AM
????? ok
Old Apr 16, 2008 | 01:08 PM
ss.slp.ls1's Avatar
But that's what's always recommended with a M6.
HectorM52
Jul 30, 2017 11:46 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
lt1-xjs
Jan 17, 2015 07:52 PM
Queens94z28
Dec 20, 2014 09:11 PM
Jul 4, 2005 05:00 PM
