spark, fuel, compression but no start on a new motor
Old Feb 10, 2010 | 11:55 AM
gillta95's Avatar
I have spark, fuel, and compression but the starter turns the flywheel for 1/8-1/4 turn without start up. I'm not sure of the check the fuel pressure since only the return line with come off. It has spark from the plugs, and I tested the compression when installing the heads. I dont have the cold air intake installed. The motor cranks but no start. Any ideas?
Old Feb 10, 2010 | 12:03 PM
Wow.... that's a confusing sentence. You indicate you have fuel in the topic, but that sentence appears to indicate you don't know how/where to measure the fuel pressure. Is that correct?
What happens after the starter turns the engine 1/4 turn - stop dead? How is the starter responding to that sudden stop?
What, if any, mods on the engine?
Old Feb 11, 2010 | 10:52 AM
gillta95's Avatar
Sorry for the confusion, I have fuel but do not know how to check the fuel pressure. The motor is a 383 high compression stroker with all bolt ons. When the starter turns, the flywheel turns in which the a/c, alternator all turn. However after that the motor wont start. I'm not sure how to answer the question about how the starter responds to suddenly stopping.
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
FIREBIRDMARK1
Jan 7, 2015 03:36 PM
Jazsun
Dec 29, 2014 12:14 PM
