Spark but no start
Old Mar 4, 2008 | 04:08 PM
  #16
It is not intended that the "other two" hour-glass shaped holes be used for anything. Unfortunately, it is possible to insert the dowel pin in those holes, resulting in a no-start conditiion. You would be 120-cam degress (240 crank-degrees) "off" using one of those holes.
Old Mar 4, 2008 | 04:20 PM
  #17
ss.slp.ls1's Avatar
It will slide in, but I've never gotten the opti to sit flush with the pin in the wrong opening.
Old Mar 4, 2008 | 07:32 PM
  #18
texas97z's Avatar
I wish they wouldn't build them that way, but either way, not the case with mine. Never made that particular mistake, just others.
Old Mar 4, 2008 | 09:56 PM
  #19
Unfortunately, many people have managed to pull it flush with the bolts, ending up with the timing completely screwed up.
Old Mar 4, 2008 | 10:27 PM
  #20
88IROC_Z's Avatar
do you know what year car the crank was out of????
Old Mar 5, 2008 | 07:52 AM
  #21
texas97z's Avatar
crank is out of a 95 trans am. Had the same casting # as mine.
Old Mar 5, 2008 | 08:31 PM
  #22
texas97z's Avatar
Ok, found a split in the wire from th ICM to the PC, fixed it, checked the rest of the wire to the PCM(good), and still no start. Checked the partial harness to the opti(good) and the rest of that harness back to th PCM(good). The coil sparks like it should, but when you pull a plug and ground it(coming off the opti), the spark is very slow and weak still. I am leaning towards something to do with the opti, but what? Again it is brand new, never been started, and no fluid has ever been in it.
Thanks for the help from everyone so far.
update: Just wanted to let everyone know what happened. As embarrising as this is, the mechanical timing was off. Fixed that and car started. Word to the wise, always double check the work being done by you or your friend. Leave nothing to chance.
Last edited by texas97z; Mar 23, 2008 at 07:13 PM. Reason: didn't want to go to the top of list.
Noenav
Mar 1, 2019 07:38 AM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
FIREBIRDMARK1
Jan 7, 2015 03:36 PM
Noenav
Dec 6, 2014 07:35 PM
