Sounds stupid, but please answer
Old Sep 15, 2003 | 11:21 PM
1995ta's Avatar
I dont want to use my dipstick. I have no need for it even though it sounds stupid. I cant get it to go back in after the header install and now its leaking. Is there a way I can remove the dipstick tube and plug the opening in the pan somehow?
Old Sep 15, 2003 | 11:26 PM
jchevy's Avatar
I have heard that if you take some sand paper and kind of sand down the outside circumfrence(sp) of the tube where it slides in it will make it a lot easier to get in.
Old Sep 16, 2003 | 03:36 PM
1995ta's Avatar
TTT
Old Sep 16, 2003 | 04:06 PM
BradZ28's Avatar
Sand down the part of the tube that enters the block. Make sure and wipe away any metal shavings from the sanding and use a hammer to tap it back in from the top. A friend will help alot!
Brad
Old Sep 16, 2003 | 04:18 PM
ibanez6rg's Avatar
Golf tee?
Old Sep 16, 2003 | 04:22 PM
joeSS97's Avatar
You really should have a dipstick.You have to get the bend on it right.Sanding ,then a little grease on it will help.Someone to help you with it may get the job done.Once you get it started in the hole put a screwdriver in the top of the tube to tap it in.
Old Sep 16, 2003 | 04:43 PM
revtime's Avatar
Brett.
Don,t do anything until I come over and take a look at it.
I think we can get the dipstick in without issues but hey if we can,t then I will bring my tubing cutter over and we will do what I did and chop a little off the tube.
Mine works fine and it was alot easier to get in.
You need the dipstick man so don,t go plugging up the hole.
This weekend I will come over so give me a PM on MOGMHP or something and let me know what day is good for you.
Latronaxe
Jul 17, 2015 11:55 AM
GT what?
Jul 14, 2015 10:17 PM
asilomar244
Jul 12, 2015 05:53 AM
surreybrad
Jul 5, 2015 10:36 PM
FredM
Jun 5, 2015 05:45 AM
