Solid Pinion Spacer Worth It for Gear Install?
Old Jul 7, 2003 | 10:53 PM
Brandon 95 Z28's Avatar
Im about to install motive 4.10's in my M6, and was wondering if the solid pinion spacer is needed. Im going to use the ratech complete installation kit, and had not even heard of the solid pinion spacer untill reading some back posts. Just wanting some opinions on if its needed and what its main purpose is.
Brandon
Old Jul 7, 2003 | 11:01 PM
Re: Solid Pinion Spacer Worth It for Gear Install?
Brandon
I believe it's main function is to help eliminate pinion bearing preload changes due to drivetrain shock loads (like hard launches).
TitoPR221
Jan 29, 2015 08:00 PM
97SSdude
Dec 31, 2014 07:43 PM
Noenav
Dec 6, 2014 07:35 PM
Jul 4, 2005 05:00 PM
