Software for Laptops for Diag,Info
Old May 31, 2003 | 07:02 AM
Eliminator's Avatar
Does anybody know where you buy this stuff. I want to be able to plug my laptop into my car and get info from it for Diag. or just anything I can get thanks.
Old May 31, 2003 | 07:13 AM
jkipp84's Avatar
I use Freescan fairly often.. suits my needs. Another popular one is Datamaster. Looks like their server's down right now though..
Old May 31, 2003 | 09:36 AM
delbuort's Avatar
It also depends on what obd you have. If you have an obd2 then I've heard a lot of good stuff about obd-2.com. I just ordered the package from there myself. I'll let you know how it goes when I get it in. The package ran me $122...I think.
Old May 31, 2003 | 09:30 PM
Eliminator's Avatar
Any Idea on where to get the cables from laptop to the car from??
I have a 94 Z-28, how do you determine which obd you have I just bought the car.
Old May 31, 2003 | 09:59 PM
Here's a copy & paste of a scanner writeup that I never got a chance to put on my website:
GUIDE TO SCANNERS FOR 4TH GEN F-BODYS
There is a fairly rigid dividing line between OBD-1 (1993-1995) and OBD-II (1996/1997) hardware and software. Unless specifically stated, products will only operate in one system, not in both.
Further complicating this is the fact that the 1993 and 1994 models have a 12-pin “OBD-I” ALDL connector underneath the dashboard, near your right knee. 1996 and 1997 models logically have a 16-pin OBD-II ALDL connector in the same location. But, the 1995 models, while equipped with an OBD-I computer (PCM – or powertrain control module), have a 16-pin OBD-II connector. This means that when you buy a scanner, or a laptop connector for a 1995, you must verify that it can be supplied with the OBD-II connector, with pin locations specific to the 1995. There are “urban legend” stories about some dual-cat 1995 models being equipped with OBD-II PCM’s, but no one I know has ever found one. The 1995 “California emissions” option A4 cars are equipped with dual cats, but the PCM’s are OBD-I (and they are not rated 10HP higher than the single-cat “49-state” cars.)
A “scanner” can be a valuable tool… allowing you to identify the DTC (diagnostic trouble codes) that can be set in you PCM, and to view in real time the values for many of the sensors and actuators in the engine. Most “scanners” will not access the body control module (BCM) or the ABS control system. Most scanners can only read the sensors or PCM values, not change them.
For some info on what you can read with many scanners, and how to interpret this data, look at my “ScanMaster” writeup, linked below.
http://members.aol.com/InjuneerZZ/ScanMast.htm
For the mother load of all links related to the computer:
http://www.bfranker.badz28.com/fbody/links.htm#PCM
Another site with excellent info and links relating to scanners is AKM Electronics:
http://www.akmcables.com/
OBD-I: HARDWARE
§ AutoXray
http://www.autoxray.com/index.htm
http://www.autoxray.com/scanners.htm
GM OBD-I Scanner ($200 list/$175 at auto chain stores) - Reads trouble codes and sensors. Records 29 seconds of data. Will work on many GM vehicles, from mid-1980's. This is a good portable unit, small enough to hand-hold while driving, but the LCD display makes it sort of hard to read in anything but bright light.
§ ScanMaster LT1 - $250 from Ramchargers or T. Byrne Motorsports.
Performance oriented unit. This one is small enough to mount on the steering column, or in the A/C vent on a Z28. Bright LED display makes it easy to read. Default display is O2 mV's and knock retard. When you go WOT, it will record the minimum O2 level and the maximum knock retard, and the MPH at which each happened. As soon as you go WOT again, the new data overwrites the old.
While driving, can be sequenced through about 20 sensor and PCM value displays. It will only display one sensor reading at a time, and does not record anything other than the O2 and retard for a single WOT pass. One of the displays in the sequence it for trouble codes, and it will display all active and stored codes in a sequence. Always nice to have it read "--" for this one…..).
All features work for 1994 and 1995 only. Will NOT work on 1993 F-Body. Will work on 96/97, but will not display OBD-II trouble codes.
§ Actron CP9001 ($35):
http://www.sunpro.com/cgi-bin/web_st...=2781372_28269
The "GM Code Scanner" is nothing more than a switch in a box, that shorts the ALDL pins together. This will ONLY work on 1993 F-Bodys, and you do not need a "scanner" to do it. All you need is a paper clip. Do NOT buy this for your 1994 or 1995. It will NOT work.
§ Actron CP9110 ($220)
http://www.actron.com/cgi-bin/web_st...d=4322814_4845
§ Snap-On:
See "OBD-II" for Snap-On products.
§ OTC Tech-series
These are the GM service tools. See "OBD-II" for these products.
OBD-I: SOFTWARE
(Obviously, works best with a laptop. Requires an interface cable…. See AKM Electronics link, at bottom)
§ Diacom
http://www.rinda.com/auto/auto.htm
Old-fashioned DOS software… advantage is it works with many GM cars from about 1985. Not much else to recommend this one. Just remember, it won "Popular Mechanics" Design & Engineering award in 1991 (!!!) and hasn't been updated much since. They even spell the name of the product wrong ("DIATOM") on their website - duhhhhh)
Diacom ($279) - Codes and sensors, real time display.
Diacom Plus ($579) - As above, but adds data recording, graphing.
§ TTS Datamaster (free download - 20 run limit, cable $125; software license + cable $219)
http://www.ttspowersystems.com/
This is the Cadillac of the scan software, for OBD-I. Version available for 1993 F-Body.
I do have a question on the accuracy of the fuel injector duty cycle that is calculated within the Datamaster software. It appears to calculate a number that is too high. This needs to be investigated.
§ pcmcomm - bundled with LT1_Edit for OBD-I.
http://www.carputing.com/
Add $50 for data logging capability.
§ FreeScan (free download)
http://www.andywhittaker.com/ecu/ecu_software.htm
I have seen posts that indicate that although there is a "93" version listed for FreeScan, it will not work with 93's. I have not been able to verify this, so proceed with caution if you have a 93.
OBD-II: HARDWARE
§ Harbor Freight: The cheapest way to read trouble codes ONLY is a $50 OBD-II scanner from Harbor Freight. I think Brent Franker tried one:
http://www.harborfreight.com/cpi/cta...emnumber=46030
§ Hypertech: If you have an HPP+/III you can get a scan cartridge for it.
http://www.hypertech-inc.com/
§ Auto Xray now makes an OBD-II scanner. Look in The Eastwood Company online catalog:
http://www.eastwoodcompany.com
There are three different Auto Xray products to consider:
EZ-Link Pro-Pack ($450 list) - Scanner plus software. Reads OBD-II codes, engine sensors and other parameters on GM, Chrysler, Ford, Asian and Euro imports. Also read OBD-I.
EZ-Link OBD-II Scanner ($300 list) - As above, but scanner only.
EZ-Link OBD-II Code Reader ($160 list) - Reads trouble codes only, not sensors.
§ ScanMaster LT1:
Will not read trouble codes on 1996/97 F-Body. Will read sensors
§ ScanMaster LS1:
Works only with LS1 vehicles (98 and up), will not work with LT1’s.
§ Actron:
OBD II Diagnostic Tester - CP9035 ($200)
Global OBD II AutoScanner - CP9135
§ OTC Tech-series:
Tech 2 Flash GM Dealership Scan Tool OTC ($3,000)
http://www.aeswave.com/framedcatalog...Tech2Flash.htm
This is the bi-directional scanner that GM mechanics use. I don't expect anyone to run out and buy one, but at least you can see what it can do.
Tech 1 is the earlier version of this scanner. I suspect it may be limited to pre-OBD-II, but I do not know that. I believe you can find them used for about $1,000.
§ Snap-On
Deluxe Scanner ($1,795)
http://buy.snapon.com/products/diagn...e=snapon-store
Super Deluxe Color Graphing Scanner ($2,695)
http://buy.snapon.com/catalog/search...no=MTG25002900
These units will access ABS, airbag, body control modules, etc., in addition to the engine control module.
OBD-II: SOFTWARE
(Obviously, works best with a laptop. Requires an interface cable…. See AKM Electronics link, at bottom.)
§ AutoTap scan software.
http://www.obdii.com/obdii.html
AutoTap has expanded their product line. They now sell several scan packages:
AutoTap for Windows - KAT1WG ($200 list) - GM only, "generic" parameters:
http://www.autotap.com/generic_parameters.asp
AutoTap for Windows - KAT1WEPT ($290 list) - GM only, "enhanced" parameters:
http://www.autotap.com/enhanced_parameters_gm.asp
EFILive V5 Standard - KAT1EFISTD ($305 list) - Special features for LS1 engines
http://www.autotap.com/EFILiveV5.html
EFILive V5 Bi-Directional - KAT1EFIPRO - As above, but adds "bi-directional" communication, allowing you to temporarily alter parameters like idle speed, fuel maps, timing maps, etc….
AutoTap for PALM - KAT1PG ($200) - Appears to be the generic parameter version.
http://www.autotap.com/autotap_for_palm.html
§ Virtual Dashboard
http://www.obd-2.com/
§ Auterra scan software for Palm:
http://www.auterraweb.com/
CABLES:
Top quality products.
OTHER PCM INFO LINKS:
http://www.diy-efi.org/gmecm/ecm_inf...ion/spk747.txt
http://www.baylor.edu/~Christopher_Bennight/LT1Edit.htm
http://www.bfranker.badz28.com/LT1Edit/LT1files.htm
http://www.lt1.net/editor/Lt1page3.htm
http://www.topica.com/lists/editor/r...t=d&start=9245
http://w3.one.net/~roz/cars/z28/tuning.html
http://www.joegeorger.com/
Old Jun 1, 2003 | 08:16 AM
Eliminator's Avatar
Thanks for the info. I made sure I printed all that out for future reference to check. I did the download to Freescan and Datamaster now to get cables. Thanks again
Old Jun 1, 2003 | 08:57 AM
TransAm9585's Avatar
To use on 95?
Im gonna try and use Freescan. Where do i get a hook up for the 95 f cars. Any information would be great thanks guys.
Old Jun 1, 2003 | 09:23 AM
You must have missed this in the post above:
CABLES:
Old Jun 1, 2003 | 11:18 AM
Kuma's Avatar
lt1 edit
Will LT1edit or Tunercat allow you to do scanning and reset codes as well?
Old Jun 1, 2003 | 01:04 PM
Eliminator's Avatar
Thanks for all the info. Anybody else make sure your laptop is compatable to the cables you buy, I heard older laptops may have problems.
Old Jun 1, 2003 | 07:28 PM
Re: lt1 edit
LT1_Edit can not scan by itself. The OBD-I version comes with a bundled "scan" software (pcmcomm), that can be upgraded for extra $$$$. The OBD-II version does not include any scan software.
blac94Z
Nov 4, 2015 01:59 PM
colts0455
Oct 4, 2015 09:47 PM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
MDZ28
11
Sep 24, 2015 09:15 AM
