So i took of my opti and..
Old Dec 11, 2007 | 05:00 AM
  #31
sabedra211's Avatar
Originally Posted by shoebox
You are supposed to index the opti drive with the notch like has been already shown and said. You are not supposed to use the rotor for positioning. Do it right or it will not work.
Your damaged wire may arc to ground and not fire the spark plug.
i didnt do it right?? Sorry i dont get it. it also didnt start
Old Dec 11, 2007 | 05:57 AM
  #32
Guest47904's Avatar
Guest
I don't get it
Originally Posted by speedygonzales
you can confirm the opti is indexed correctly by putting number 1 at TDC and remove the cap. The rotor should be pointing almost dead on the 6 O'Clock position.
Originally Posted by sabedra211
Alright i took the opti off and took of the cap and i moved the spline until the metal peiceof the rotor got to the 6 oclock position and i TDC the number one piston and the opti slid right in.
Where did it say to remove the opti and then remove the cap?????
The goal was to leave the opti on the engine and see where the rotor was pointing. This eliminates a misaligned rotor as the cause of your problem.
You still haven't answered if the engine ran prior to you changing the opti.
If you use the damage wire and it misfires, you won't know for sure what the cause of the rough running will be.
Based on what you have done to this point and the questions you ask, this job is best left to a repair shop. I'm out of here.
Old Dec 11, 2007 | 06:59 AM
  #33
..... and i noticed the wire on number 8 has a gash in it. ....does this look bad???
Originally Posted by Injuneer
I wouldn't trust that wire to carry 30,000 volts without arcing to the nearest metal surface. Definitely needs to be replaced.
.....OH and u know how i have that ripped wire? wathappens if it touches metal while itss operating?? Thanks
Are you actually reading the responses?
I think you are frustrating most of the people who are trying to help you, by not reading carefully.
Old Dec 11, 2007 | 05:09 PM
  #34
SATANAZ666's Avatar
DO it!
Dont worry dude youll get it soon. I know its cold and everything, dont get discouraged.
Old Dec 11, 2007 | 05:20 PM
  #35
sabedra211's Avatar
Ha, alright so im gona spin the crank till it gets to number 1 tdc then remove the cap see if its pointing at the 6'oclock posistion?? and if it is? its a defective opti??? It could be? i baught it off ebay from the allignition seller.
ummm i dont know how this could seriusly be frustrating for you if ur over a keyboard typing words?? Im the one working on the car it should be frustrating for me. I am trying really hard to get my car to work. if u could please have some patience with me... im learning . thank you.
Yay lol thank you 4 the support
Old Dec 11, 2007 | 09:51 PM
  #36
NovaTodd's Avatar
There is nothing like a case of frostbite to re-inforce the lesson learned
Keep trying and at the same time listen to Shoebox and Injuneer. These guys know their stuff and are trying to help.
Old Dec 12, 2007 | 02:16 AM
  #37
sabedra211's Avatar
Alright i did put it to TDC on # 1 with the opti on and i took off the cap and it was at 6'oclock. i tried to turn on the car and it starteed up for like 6 seconds then it died.? wouldnt start again... . I was going 2 remove the opti and i found one of the bolts that goes to the timing cover loose. i pull it out and its broken?? i look at the other one and its also broken at the same spot. the bottom was isnt broken? The broken piece of the other bolt came out but the other one is stuck in there? how would i get this broken piece out?? Thanks
Old Dec 12, 2007 | 08:35 AM
  #38
NovaTodd's Avatar
I would pull the timing cover off and back the bolts out. You will have to loosen the front oil pan bolts and then pull the cover (trying not to tear the oil pan gasket). I'm sure you can find a write-up on someone's website, as it has been a standard practice for changing cams for years.
Formula Steve
Sep 19, 2023 08:31 AM
94Maroz28
Oct 27, 2015 04:38 PM
Ks0209
Oct 1, 2015 07:32 AM
colts0455
Sep 27, 2015 01:07 PM
jayblev95
Sep 26, 2015 09:44 PM
