what is wrong with my car
Old Dec 10, 2007 | 07:03 PM
trans 96's Avatar
Question what is wrong with my car
i recently got a code p0100 and now my car is running really rough i put my car into 6th gear and the whole car was shaking really bad. the p0100 code just came on when i put my new headers on. could something else be wrong. like a lose egr fitting? i reset the code and as soon as i cranked it up it comes right back on. wtf!!!
Old Dec 10, 2007 | 07:26 PM
joeSS97's Avatar
The shaking is more than likely a broken and/or loose plug wire.Try a search for the code,there is a lot of info to be found there.
Old Dec 10, 2007 | 07:54 PM
trans 96's Avatar
thaks for the reply but i cant seem to find any more info, all the plug wires were fine my car is running rough in all the gears but expecially in 6th at low rpms i tried unhooking the maf while running an it ran exactly the same does that meen the maf is bad?
Old Dec 10, 2007 | 08:18 PM
MeanGreen97Z's Avatar
That code is a misfire code. You have a bad plug wire. Just because it looks good doesn't mean it isn't bad. Go back push them all on firmly. Make sure they aren't burned through.
Old Dec 11, 2007 | 07:18 AM
Originally Posted by MeanGreen97Z
That code is a misfire code. ......
P0100 = Mass Air Flow (MAF) insufficient signal activity
It would be unusual for that code to show up after headers. Is it possible you got:
P0300 = Engine misfire detected
If you are getting P0100, check for +12V on the pink wire on the MAF harness connector.
Old Dec 11, 2007 | 09:01 AM
trans 96's Avatar
ok the spark plug was missfiring., and also a fuse was blown for the maf now it keeps blowing a fuse could it be that maybe i crossed a wire on my o2 sensors while hooking them up? that fuse runs the maf heated o2 sensor and also the skip shift sensor
Old Dec 11, 2007 | 09:13 AM
mzgp5x's Avatar
Since you have a 96, the four (4) wire O2 sensors each have a heater circuit. I have had a heater circuit short on one (1) of the four (4) O2 sensors which can blow the MAF fuse (all wired to same power source). This happened to me, and, was difficult to troubleshoot. I ended up cutting the O2 heater wire which was shorted. Usually a digital meter (set to ring continuity) will not find this problem due to the O2 heater circuit low resistance. I still use the O2 sensor (front right bank for me) with the hearter wire cut. Why gm wired the circuit that way is a mystery. I have since rewired it different. Hope this helps. B.
Old Dec 11, 2007 | 09:18 AM
Stoopalini's Avatar
Check the engine harness which runs near the passenger's side header. It's possible the new headers have melted some of these wires causing your problem.
This happened on my buddies '97 SS, and he ended up having to cut and extend each wire in the harness to reroute them away from the header.
Good luck,
Thomas.
Old Dec 11, 2007 | 01:26 PM
trans 96's Avatar
ok i dont see any melted wires it just keeps blowing that fuse
Old Dec 11, 2007 | 02:12 PM
trans 96's Avatar
i found that my o2 sensor simulator was melted so i thought i found the problem but when i un-hooked the simulator and replaced the fuse and started it up there goes the fuse again! could it be blowing because nothing is hooked up to my o2 senjsor connector? or is there another problem???
Old Dec 11, 2007 | 02:32 PM
Stoopalini's Avatar
How did the simulator melt? The sims aren't plugged into the front O2 connectors, are they?
If it is the rear connector, check the wires as they could also have melted.
Thomas.
Old Dec 11, 2007 | 02:48 PM
trans 96's Avatar
no it was pinned up on the passanger side close to the headers (someone else did it) but none of the wires are melted they are all perfect. could nothing being pluged into the outlet cause it to pop the fuse?
Old Dec 11, 2007 | 05:07 PM
trans 96's Avatar
everything is all good now i figured out it was were the dude that wired up my o2 sensors crossed a wire thanks everyone for all the help trans 96
Old Dec 11, 2007 | 05:29 PM
Oops!!! I was thinking PO300. Sorry! haha
Old Dec 12, 2007 | 08:54 AM
trans 96's Avatar
no it was miss firing one of the plug wires was not on tight thats why it was ticking thanks for the help
ModdedNerd
Dec 18, 2014 10:52 PM
brentbrowning01
Dec 16, 2014 06:35 AM
USAirman93
Nov 24, 2014 03:37 PM
DrMilhouse
Oct 2, 2002 05:03 PM
JoeD316
Aug 16, 2002 09:12 AM
