smokin
Old Apr 8, 2003 | 10:53 PM
vampdlight21's Avatar
smokin
my car blows out smoke when you at least try to get on it a little bit. Also i have noticed that it needs oil about every other month i have not noticed any power loss or anything and everyone tells me something different about it. does anyone know what my problem is?? the car does not have may miles around 60,000
1996 camaro z28 convertible
Old Apr 8, 2003 | 11:20 PM
chasmanz28's Avatar
Re: smokin
if your useing oil and you see smoke i would think rings are going and your getting a blowbye situation, if you see smoke as you first start the car, valve seals are shot, but you said as your driving so i would think its the rings
Old Apr 8, 2003 | 11:37 PM
Wild1's Avatar
Pull your plugs. If you find a couple that are glossy/sludgy black, then you just found which cylinder is burning oil. Do notice if the smoke has a hint of blue and/or smell sweet?
Old Apr 9, 2003 | 07:49 PM
the smoke looks kinda blue as for the smell of it ive never been behind it so ive never smelt it
Old Apr 9, 2003 | 09:49 PM
25th-transam's Avatar
Hey man, i'm in the same situation as you, except i've checked all of the plugs and none of them are any different than the other and nothing looks out of the ordinary. Mine is losing oil out my rear main bad, but im not sure if its burning some. I can rev it up at a standstill and it doesnt smoke, just when im driving everyone tells me it does.... its a mystery to me.
kurt
Old Apr 10, 2003 | 06:05 PM
sounds exactly like mine. Exept mine does leak but not very much it is only noticible where i park it often.
Old Apr 11, 2003 | 01:48 AM
Fatdog's Avatar
Cool
When I had my intake oil leak fixed,all signs of smoking disappeared.I would see smoke on startup,and when I blasted it.Even my #8 plug showed thick oil and gunk on it before the intake fix.Now all plugs look good after 5000 mi or so.No more smoking,and I hardly use any oil between oil changes,where as before I used about a quart a month.Hope this helps.
Old Apr 11, 2003 | 04:30 AM
alex-z28's Avatar
my car does the same thing it has 65k on it. when I first start it I can see blue smoke coming out and then its gone, also my exhaust smell little bit like oil. I have talked to few people and they told me that its valve seals, am planning to change them soon, I hope that will solve the problem. Just wandering how can I tell if my intake has oil leak?
Old Apr 12, 2003 | 01:46 AM
Fatdog's Avatar
Cool
It usally drips(spreads) down over the trans.My02
z28smokin
All Non-Automotive
Nov 29, 2005 05:16 PM
96YenkoClone
Advanced Tech
19
Jan 26, 2004 03:29 PM
96YenkoClone
Jan 16, 2004 06:35 PM
MadMaxz28
Sep 15, 2003 10:15 PM
