Smoke after any freeway drive...
Old 01-23-2004, 04:07 AM
96 WS6's Avatar
I get smoke mostly from the driver's side when I stop from a highway trip. No matter the distance... I don't know if it's the intake or not but I felt back there and it didn't seem like there was much oil. It wasn't dry but it looked like usual accumulated road grime. Plus my car has been leaking a decent amount of oil lately. What else could it be other the intake manifold... Something is leaking oil and it's getting all over the underside of my car and everywhere I park I leave a small little pool of a few drops.
96 WS6 is offline
Old 01-23-2004, 05:10 AM
97WS6SCharged's Avatar
Ok, you know there's an oil leak. Where exactly is the oil coming into contact with the exhaust pipe? I'm assuming it's hitting the exhaust cause that's the only thing I can think of that is hot enough to make the oil smoke.
97WS6SCharged is offline
Old 01-23-2004, 05:23 AM
slopokrodrigez's Avatar
Clean it real well. Get some die and put it up on a lift and be done with this problem.
slopokrodrigez is offline
Old 01-24-2004, 10:09 PM
96 WS6's Avatar
Could this be intake manifold leak? I did not scratch up the mating surfaces before I did it this time... I will clean it and drive it and feel back there to see if oil appeared but as for now I can'treally tell.
Anybody have input???
96 WS6 is offline
Old 01-25-2004, 12:00 AM
mike95z28
Guest
Posts: n/a
How about the oil lines that go to and from the blower? I remember those giving some trouble before with oil leaks.
The valve covers? Are they sealing all the way? Check around there too.
Check the timing chain cover too.
Old 01-25-2004, 12:11 AM
T/A#4's Avatar
Hmmmmm I had the same problem with my 1980 Turbo T/A. Turned out the rear main would leak under high boost. This usually happened on the freeway.
T/A#4 is offline
Old 01-25-2004, 06:19 AM
96 WS6's Avatar
Whatsup Mike...
I'm pretty sure it's not a rear main seal problem. It's never given me problems. It has to the the intake or the oil lines to the blower. I'm really starting to think it's the intake though. I just have one of those "feelings". I replaced the valve cover gasket with a felpro one so it's not leaking any more for sure. I will investigate and post back.
96 WS6 is offline
Old 01-25-2004, 01:10 PM
mike95z28
Guest
Posts: n/a
It'd be obvious if the rear intake was leaking though. Then again.. you'd have to stick your hand back there on a hot engine to see if there's wet oil.
Rear main seal would be obvious if you pulled the clutch inspection plate.
greenzee28
09-25-2015 04:29 PM
jackpawt883
09-10-2015 08:53 PM
blaze309
09-08-2015 05:27 PM
86z28original
3rd Gen / L98 Engine Tech
08-20-2015 12:20 PM
alphaauto
07-26-2015 04:40 PM
Quick Reply: Smoke after any freeway drive...
