Smaller Alternator for Valve cover clearance
Old Mar 18, 2010 | 09:37 AM
DirtyDaveW's Avatar
Have any of you tried the smaller GM alternator to gain clearance for 'standard' valve covers?
Here's an Fbody, an Impalla SS and a Caprice Alternator. I cut and pasted these images from Autozones site. It 'looks' like the Caprice version is smaller. I just don't know if it's small(er) enough to clear the passenger side valve cover on the LT1 Fbodys.
Old Mar 18, 2010 | 02:25 PM
What are the amp ratings? The LT1 uses a 140-amp alternator.
Old Mar 18, 2010 | 02:48 PM
DirtyDaveW's Avatar
It's only a 105amp, but I don't have a big stereo or other things that could overwhelm the system. At least, I can't think of anything that would cause 105 to be inadequate. I'd have to see what the draw is when
  • driving
  • lights on
  • wipers on
  • electric water pump
  • AC/Heater blower fan on high
Old Mar 18, 2010 | 03:42 PM
Mystery Bird's Avatar
Here is an easier solution: http://www.lt1engine.com/tech/how-to...-valve-covers/, or just relocate it.
Old Mar 18, 2010 | 06:14 PM
Then you have to ask yourself, why did GM waste money by providing a 140-amp alternator?
Old Mar 25, 2010 | 06:09 AM
maybe2fast's Avatar
This is a good point! I just hate how ugly that thing is!
Old Mar 25, 2010 | 07:21 AM
DirtyDaveW's Avatar
I decided to punt on this one. Too much trouble. I now have a box of brand new 7/16" stud 1.7 Scorpion aluminum rockers, new in the box that will stay that way. I just put my CC 1.6 ProMags back on. The motor will have the Canton valve cover on the passenger side and the Jegs Cast Aluminum on the drivers side. I will say, getting the gasket sealed on the Canton is a Pain in the ***. As per Cantons instructions, you have to glue the gasket to the valve cover. Well, there's no continuous retention rail to keep the gasket in place. The FelPro gasket kept trying to pull inwards. I ended up using clothes pins and vise grip pliers(on wood shims) to keep the gasket in place while the silicone sealant cured. If you're wondering why i have the Jegs VC on the drivers side, the Cantons are so wide, it hits my turbo hotside. The stock VC only cleared the hotside by 3/8" or so. The taller and wider Cantons rest right on the hotside. The link above that attempts to show how to clearance the Alternator to clear 'tall' valve covers are depicting shorter valve covers than I have. There's no way I could butcher my alternator enough to clear these particular VC and the alternator still function.
Old Mar 25, 2010 | 01:18 PM
Revolutionary's Avatar
I use that smaller alt on my LT1 and it clears the common cast aluminum perimeter bolt valve covers (easier to use w shaft rockers). Just made a little bracket and it works fine. You can get one wound to about whatever amp rating you want.
HectorM52
Jul 30, 2017 11:46 AM
nikolt1
Feb 27, 2015 09:10 PM
HectorM52
Jan 30, 2015 11:34 PM
Snoman73
Nov 17, 2014 07:22 PM
Jul 4, 2005 05:00 PM
