slver bullet, gotta question 4 ya.
Old Apr 3, 2005 | 04:00 PM
redzracing's Avatar
How are you liking that LE3 heads/LE2 cam setup? Does it idle good? Did u have it dyno'd? if so, how much u makin? Sorry to be so nosey, but I had the same exact setup in mind, and i'm still considering it. Ive talked on the phone alot to lloyd about this, trying to get everything on a list, did you upgrade your oil pump or go stock? I seriously considering the STS system for mine ('97 Z M6) its a little cheaper and easier to install. The main thing is that the STS has a little less power than what the H/C package would be but has a heck of alot more torque. I would appreciate the help. I'm gonna do one or the other but not both, so Im havin a hard time deciding. Thanks, Brian
Old Apr 3, 2005 | 04:26 PM
slverbullet's Avatar
Re: slver bullet, gotta question 4 ya.
lol, you could always pm me.... but since ill be giving some props to all those that helped me put together an awesome setup (Lloyd, Bret, Ion mostly...and a lot of the guys from this website), ill go ahead and post a reply here.
i have no means for a direct comparison to an f-body with an sts turbo on it, so ill only be able to give you information on how my car rides.
i actually got all my bugs worked out on friday night. my optispark went to crap with the new motor and i couldnt rev past 5k rpms. but let me say that since the fix, the ride is completely unreal (keep in mind that i went from a completely stock car to the car in the signature below). when i took it out on friday, i almost crapped myself. seriously. when i hit second gear and almost did a 180*, it scared the hell out of me (in a good way). so now ive learned to drive it a little better since then. it idles awesome. i get nothing but nonstop compliments on the idle. i think the idle alone is a good enough reason to get this setup. you feel like such a bada$$ in this thing. i use it as a daily driver so it isnt too harsh IMO. w/ 4.10 gears at highways speeds (~70mph) i cruise at ~2k rpms. i get better gas mileage with this setup than with my old setup (about 240 miles per tank). i havent had it on the dyno yet, but will get it there in a couple weeks. ill keep everyone posted as to what power it makes. i had a friend ride with me the yesterday and claimed that when i took off, it gave him that feeling that his stomach dropped (the feeling you get on a roller coaster when you go over a steep hill). as far as my oil pump went, i bought a new (stock type) pump with the white (higher pressure) spring. it is absolutely the coolest thing youll ever get. i would recommend this setup to anyone. let me know if you have any other questions.
Old Apr 3, 2005 | 04:42 PM
redzracing's Avatar
I appreciate the info, I didnt pm ya because i thought some other people might wanna know the same. I guess im in your shoes too bc i have a completely stock LT1 M6, I'm sure you cant go wrong with either one of the setups but I couldnt imagine the sound of the blowoff valve on my car everytime i shift, likewise I havent talked to anyone that has a STS kit (i guess bc theyre so new) but the dyno results from 7psi on their site was 394 HP and 450 TQ, I've seen a dyno result from the LE2 package and the HP was about 410 and TQ was about 360 if I can remember right. But regardless, Im not saying either one of them is better than the other. Im just havin a hard time deciding. Thanks alot for the info
Old Apr 3, 2005 | 05:11 PM
on sts's sight, are those numbers the amount of power to the wheels or at the crank? just curious.
i also considered the sts, but went with the current setup due to, IMO, better reliability. from what ive read, at 7psi on a turbo and a stock motor, you wont be running it too long because of the stock CR. your going to be spending just as much money if not more to make it a reliable daily driver.
i'm sure the blowoff valve would sound good but not near as good as the LE2/3 idles. wait till you hear one in person. these soundclips do them no justice. i cant believe how loud the intake of air on these things are. i can actually hear the intake of air through the CAI over the sound of my exhaust while in the car (at a low idle...like through a parking lot or something. sounds cool though, nonetheless). and just to clearify, i didnt buy these parts because of the "cool" sound that they have. just an added bonus that i enjoy.
Old Apr 3, 2005 | 08:47 PM
redzracing's Avatar
those numbers on the site are rear wheel. I have considered the stock bottom end on my car with the 7 psi on it, even lloyd said the stock bottom would hold up good as long as it was about 8 lbs or less. lol now you got me wanting to hear yours, you going on the power tour this year? I think itll end up around your area this year.
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
pologreen97z
Dec 2, 2014 10:42 AM
RedLineRev
Jan 23, 2003 03:51 PM
rje
Sep 9, 2002 12:35 PM
dansam
Jul 20, 2002 01:10 PM
