SLP Fan Switch install, where to....
Old Aug 25, 2011 | 10:08 AM
jonesz28's Avatar
I did a search and was unable to see any real installs for this. Not that it is complicated at all i just was wondering, in what area did people drill through the firewall to route the switch? I havent a clue where. To the people who have done it or know of it being done, where is the most convenient/effective area to route the switch through the firewall? Any little "tricks" to make it easier or things not to do? If this is in wrong section i apologize, seeing as is a fan switch it could fall into Lt1 or audio/electrical so....
Old Aug 25, 2011 | 10:24 AM
RamAir95TA's Avatar
Re: SLP Fan Switch install, where to....
The best place to route wires is already drilled and grommeted for you. Behind the PCM, passenger side, is a large grommet that is fairly easily accessible from under the glove box. Go at it!
Old Aug 25, 2011 | 10:27 AM
jonesz28's Avatar
Well shi*, that takes care of that! LOL...thanks fella
Old Aug 25, 2011 | 11:26 AM
Some info on routing wire through the firewall.
Old Aug 25, 2011 | 08:13 PM
jonesz28's Avatar
RamAir was spot on. Installed it 10 min after seeing his post and it was a piece of cake. Routed it through the grommet, under the dash and mounted the switch right underneath the lighter. It was like Chevy left a nice, square space right there for that exact purpose Thanks!
Richardan15
May 30, 2015 08:36 AM
Rich_z28
Aug 29, 2002 11:01 PM
Rich_z28
Aug 29, 2002 10:44 PM
Rich_z28
Aug 27, 2002 12:20 AM
slothgrant
Aug 22, 2002 03:01 PM
