Slow Priming Fuel Pump
Old Aug 17, 2013 | 07:38 PM
LowRyter's Avatar
My 94 Z has 161k miles on it. It takes a couple of tries to start. Apparently the fuel pump takes a couple of tries to get pressure. A replacement is $80.
advice and comments appreciated
Old Aug 17, 2013 | 08:21 PM
Re: Slow Priming Fuel Pump
Could be a faulty check valve in the fuel pump. Check the fuel pressure - see what pressure it primes to, and how fast the pressure drops off. Will it start faster if you cycle the key a few times before you turn it to "start"?
Old Aug 18, 2013 | 01:17 AM
LowRyter's Avatar
Fred, I cycle the key 3 times to start
Old Aug 18, 2013 | 08:58 AM
All the more reason to verify pressure with a test gauge.
Old Aug 18, 2013 | 11:23 AM
You have to determine how fast the pressure bleeds down. If it does bleed down rapidly, could be due to:
-faulty check valve in pump
-leaking fuel pressure regulator
-leaking injectors
-leaking fuel lines, including the on in the tank
grabbem88
Apr 16, 2015 06:57 PM
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
