Single plane for a healthy low clearance 383?
Old Sep 18, 2008 | 12:51 AM
LT1 POWR's Avatar
I'm putting together a 383 with healthy SBC heads converted to reverse cooling and need opinions on what intake to run. I figure I won't need to have the intake converted since the heads will accept SBC EFI intakes, so why not upgrade to a single plane. The heads have been fully ported and flow 330+cfm at .700 lift.
Motor will have all forged internals and my goal is 700 rwhp without going over 6500rpm. It will have either a D1SC or a F1A. Car will be strictly street.
I'd like to keep everything tucked under my SS hood with little to no cutting of the cowl or hood, and if at all possible, keep my 4 point STB, might get a 3 point if needed.
I've got a Vic Jr and a nice 1350cfm 4 barrel throttle body. I would like to use the 4 barrel throttle body, but I guess a 90º elbow and a stock 58mm or equivalent wouldn't be out of the question. Is the Vic Jr a decent single plane for my application or would a Super Vic or an Accel be better suited? I like the Vic Jr because of the lower clearance, but hear that it isn't the "best" single plane.
So what are my options and has anyone done anything similar?
Old Sep 19, 2008 | 09:39 AM
rskrause's Avatar
Moderator
Will a V Jr. fit under a 4th gen hood?. It would not be the best intake because of the relatively small runner cross section. But if it fits and you to keep the stock hood, it should work ok.
Rich
Old Sep 19, 2008 | 05:02 PM
LT1 POWR's Avatar
Rich
I'm assuming it will, it looks relatively low profile, but I haven't taken any measurement yet. I have a SS hood, so some of the box area/support area might be able to be removed for clearance.
Old Sep 25, 2008 | 10:47 PM
LT1 POWR's Avatar
Anyone running anything similar?
Old Sep 25, 2008 | 11:34 PM
I don't know what kind of manifold he was running, but this all fit under the stock SS hood. There were some modifications made to the internal structure of the hood though. Engine was a Dart Iron Eagle SBC with Brodix heads.
http://www.injuneer.com/images/photo.../DCP03825a.jpg
Old Sep 26, 2008 | 07:32 AM
rock1501's Avatar
I have a super vic with a custom elbow and a 90mm acufab t.b and it kinda clears the stock hood(not ss stock z28 one)
I had to cut some of the bracing on the inside of the hood and the hood still touches the t.b when closed but it still closes
I plan to get a new hood eventually but but its a ways down on my priority list
damn your heads flow good I wish mine would flow even 300
Old Sep 27, 2008 | 04:01 PM
LT1 POWR's Avatar
Is anyone using a TB that mounts on top of the intake like mine and then have an elbow on top of that?
Anyone think this would fit with little to no cutting of a fiberglass(non-functional) SS hood? I'm hoping that the recessed area for the "ram air" section will be enough for the elbow.
I'm thinking something either like this or something custom for the elbow.
This is in a 68 camaro btw.
Old Oct 14, 2008 | 11:53 PM
LT1 POWR's Avatar
Anyone have any input?
Old Oct 17, 2008 | 04:25 PM
NJLT1SS's Avatar
I will try to take some pics of my setup over the weekend. I’m running a World Products single plane, Wilson Elbow and a NW 90MM LS1 TB. I had to cut some of the bracing out where the back of the elbow hits the weather-stripping. I also had to cut the area out under the scoop. I will take some pics and it will show what I’m talkin about.
Nick
Old Oct 21, 2008 | 11:27 PM
NJLT1SS's Avatar
I like the 90 degree elbow with a 90mm TB versus the 4 barrel style. Here are pics of my setup, along with what had to be cut on the hood....
Nick
Old Oct 22, 2008 | 09:00 AM
slomarao's Avatar
Nick
Thats one nice setup.
Old Oct 22, 2008 | 10:10 PM
LT1 POWR's Avatar
The problems I have read about with the "BIG" single blade setups(like the 90mm) and lean tip in makes me want to stick with my "4 barrel"(its more like a LT1 twin 58mm and a monoblade put together), nice throttle response/drivability under part throttle, but lots of CFM when needed.
Old Oct 22, 2008 | 10:13 PM
LT1 POWR's Avatar
Plus, I think if I build my own "elbow" and use the 4 barrel, I can keep the clearance to a minimum, maybe even less than with the intakeebow.com elbow and the 90mm.
Old Oct 23, 2008 | 12:47 AM
LT1 POWR's Avatar
What about something like this.
http://store.summitracing.com/partde...rsview=sku&Ns=
Would it have any advantages over either a stock, ported, or edelbrock LTX manifold?
Old Oct 24, 2008 | 04:47 PM
Masnart39's Avatar
The Procharger hat won't fit under a stock hood pointing forward. It will almost fit if turned to the passenger side, towards the firewall. That would still require milling the the surface that mates to the TB on an angle so that it tilts down slightly. At least that's what I found on my Accel single plane & 4bbl style TB.
I was able to take the Accel 90 deg elbow, and take a pie cut out of it tilting it down to fit.
