Should I start this motor?
Old Feb 9, 2005 | 07:16 PM
lt4 fd's Avatar
Its been sitting for 3 years with no fuids in it, I can turn it over by turning the crank pulley by hand. I was just curious if any gaskets could have rotted away and would be worth replacing before I put the motor in the car or if I should just not worry about it and crank on the bitch. Also would it be worth priming the oil system before hand and how do you do this? Thanks again board!
Old Feb 9, 2005 | 07:41 PM
sw89lt1's Avatar
Re: Should I start this motor?
mine sat for about that long, i started it with no problems
Old Feb 10, 2005 | 12:37 AM
lt4 fd's Avatar
wow I figured SOMETHING would be wrong lol.... anyone else?
Old Feb 10, 2005 | 01:50 AM
MaxLean's Avatar
nope, should be fine!
Old Feb 10, 2005 | 02:12 AM
BlackLT1_TX's Avatar
I'd prime the oil system. Just pull the intake and the drive mechanism at the back and use a SBC oil pump priming tool and a drill. Wouldnt hurt to put new intake and t/b gaskets on it anyways, and then you wont have a totally dry start.
Old Feb 10, 2005 | 02:20 AM
97WS6SCharged's Avatar
Prime the oil system really well. Might not hurt to pull the plugs out and put a little oil in each cylinder and turn it by hand to make sure everything is nice and lubed.
Old Feb 10, 2005 | 09:05 AM
madwolf's Avatar
I bought a motor which sat for 3 years about a year ago. The only thing that was wrong with it is that the injectors got clogged and were not spraying anymore. I had to replace all of them.
Other than that, it's working fine. I did replace a lot of gaskets on it though. (not because they were leaking but because I did a cam swap)
Old Feb 10, 2005 | 09:20 AM
It couldn't hurt to pull the valve covers off and dribble some oil over the rockers.
Old Feb 10, 2005 | 11:43 AM
lt4 fd's Avatar
I guess when I add oil Ill pour it over the valvetrain then prime it with the intake off... I dont know where to start looking for an SBC priming tool..? and will it fit into any old electric drill? Sorry for the ignorance...
Old Feb 10, 2005 | 11:51 AM
1SlowFormula's Avatar
Any parts store will have one, and Yes the will normally fit in any drill! Good luck. Mine has never sat that long but it has sat for almost a year once and I just changed the oil and fired it up. No prblems!
Old Feb 10, 2005 | 02:07 PM
lt4 fd's Avatar
ok I may need some more expaination of what to actually connect the prime tool to if its not obvious once I get the motor installed... but that will come later...
Alex Barnes
Jan 24, 2015 10:21 PM
NewsBot
Dec 28, 2014 06:20 PM
1LEThumper
Jul 14, 2003 12:45 PM
guionM
14
Jun 19, 2002 08:30 AM
