Should I replace the opticrap?
Old Jan 28, 2004 | 08:49 PM
88RX7LT1's Avatar
While i've got the engine apart, should i replace my working optispark? Ive got about 45,000 on my 95 lt1. whattayathink?
Old Jan 28, 2004 | 09:02 PM
Fatdog's Avatar
Cool
IAnd the water pump as well.I would.My02
Old Jan 28, 2004 | 09:06 PM
Zerosheaven's Avatar
Old Jan 28, 2004 | 09:17 PM
88RX7LT1's Avatar
Water pump and optispark??? ****, sounds like about another $500. When will it end??
Old Jan 28, 2004 | 09:25 PM
ibanez6rg's Avatar
Well, you could convert to an electric waterpump.
Old Jan 28, 2004 | 09:55 PM
Heatmaker's Avatar
Advanced Member
it's not the opti that goes ouyt usually it's the WP....cop a meizre or csi
Old Jan 28, 2004 | 10:08 PM
ROADRAGE's Avatar
They were working well before, so why replace them now. It only takes an hour or so to swap them, why spend the $400 if you dont need to.
Old Jan 28, 2004 | 10:25 PM
88RX7LT1's Avatar
I like it; if its not broke, don't fix it. The (potential) problem is that the engine is stuffed in an 88 rx7 convertible. I think the "hour or so" estimate probabl doesn't apply, since the radiator has to go to access the front of the engine.
Still, i think im leaning towards putting the goods back rather than spending the bucks.
Old Jan 28, 2004 | 10:30 PM
formula383's Avatar
I wouldn't change them unless you think there may be something wrong with them.
Old Jan 29, 2004 | 07:29 AM
IDOXLR8's Avatar
Ditto
Old Jan 29, 2004 | 07:33 AM
Hyperspeed97z28's Avatar
I'd change the opti and the waterpump, Probably about $275 in parts from CROMER, its insurance that you wont have to be in that area again for some time at least..
Old Jan 29, 2004 | 09:09 AM
Will84's Avatar
If you decide to change the Opti... I will sell you one, never used, for 190 + shipping. I will also include the WP gaskets and Opti seals.
You will not get it cheaper than that. I just bought it 2 weeks ago from SamTaylor Chevrolet. It was $210 plus shipping, plus I had to buy wp gaskets and opti seals.. which was proly about $6-$7. My problem ended up being the coil. I should have done more research before listening to everyone else.
Let me know if you're interested.
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
ANDYZ28
Dec 29, 2014 09:13 PM
Hurin
Dec 13, 2014 07:38 PM
supercharged94Z28
Feb 24, 2003 10:22 PM
ZBLKHELLRZR
Aug 18, 2002 07:57 AM
