Should i replace my opti spark distributor?
Old Apr 13, 2008 | 05:19 PM
RCMcamaro's Avatar
I have been fixing a oil leak in my cam seal. When i took the opti spark distributor off oil came out the top electrical plug when i tiped it. The car ran fine when it was together but i took everything out to fix a oil leak and thats when i noticed that there was alot of oil coming out of the opti spark top plug.
Should i be worried about putting the opti spark back on? If so i may just go ahead and spend the money to replace it.
Old Apr 13, 2008 | 05:25 PM
You would have to judge by looking inside the opti. If you are lucky, the oil did not get in. Perhaps you just have a bad seal on the opti harness plugging into it.
Old Apr 13, 2008 | 05:44 PM
95Blackhawk's Avatar
I would definitely get in there and clean it out.
Old Jun 30, 2011 | 03:33 PM
bobbyk3lly's Avatar
Re: Should i replace my opti spark distributor?
i agree with that, get in there lean it out with a can of conpressed air, but be carefull not to bend or break anything. if there is oil in there im not sure if you could just clean it out or you would have to buy another unit.but if it ran fine before hand, i would just clean it out and put it back on after words
Old Jun 30, 2011 | 03:36 PM
Dude, why are you digging up all these years old opti threads?
Old Jun 30, 2011 | 03:39 PM
bobbyk3lly's Avatar
didnt see the date sorry
Old Jun 30, 2011 | 03:40 PM
detroitlt1's Avatar
Old Jun 30, 2011 | 05:15 PM
Enough!
grabbem88
Mar 18, 2015 01:25 PM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
Iamherefornow
Jan 26, 2015 04:57 PM
brentbrowning01
Dec 3, 2014 10:36 PM
Brett 91 RS LT1
Mar 12, 2003 10:02 PM
