Should I Buy this 383 Block?
Old Mar 18, 2019 | 09:19 PM
Victor1096's Avatar
So im a complete noob when it comes to bottom ends. Mine is stock with LE2 heads and a lloyd elliot cam. There is a guy local to me selling a 383 short block for 1500 bucks. He says it has a Scat cast steel crank 9000 series, Scat forged I beam rods, Mahle forged pistons and new freeze plugs. says compression is 11ish:1. Does this sound like a decent bottom end for the price? Questions I should ask him? This is a daily driver car for me in the summer.
Old Mar 19, 2019 | 09:50 AM
Midnight_Z's Avatar
Re: Should I Buy this 383 Block?
The scat 9000 crank is said to be good for around 500fwhp and 6500 rpm. Anymore than that and a forged crank is recommended.
Old Mar 19, 2019 | 11:17 AM
cardo0's Avatar
Without checking all the bearing clearances, ring gaps, piston to cylinder clearance and a balance sheet you really don't know if it's even usable.
Good luck.
Old Mar 21, 2019 | 04:18 PM
Chimera96's Avatar
Originally Posted by Victor1096
Questions I should ask him? .
ask "do you have the build/balance sheet"...if answer is no, walk away
Old Mar 25, 2019 | 10:27 AM
Interesting recent thread on another site, showing a bit of a problem on a 383ci LT1 using the Scat 9000 crank and rods:
Tony’s Z rebuild thread
Old Apr 2, 2019 | 08:47 AM
KW Baraka's Avatar
Yep.....that can be an issue, right there.
KW
TheBlur
Jul 19, 2010 09:54 PM
lgz28
Sep 16, 2006 12:06 PM
SantaCruz163
May 22, 2004 02:52 PM
99huggerorangeZ
Advanced Tech
Nov 13, 2002 06:42 PM
lt1car
Oct 28, 2002 06:01 PM
