shorter or longer pushrods
Old Nov 30, 2003 | 08:35 PM
97Z-M6's Avatar
the reason i ask is becuse ive heard if you milled you heads enough you will need shorter pushrods. but if you go to high of a lift you will need longer.
im going to mill my heads .020 and im going to have a lift of .595. i had to put longer valves in the heads so i figured longer pushrods but im milling my heads. so can someone tell me what i need to buy (length).
Old Nov 30, 2003 | 09:25 PM
97Z-M6's Avatar
ttt
Old Nov 30, 2003 | 09:41 PM
streetbad's Avatar
Longer- with plus .100 valves I went 7.300. I thought I checked for length good enough,but I had to buy pushrods twice. Mine would vary. (12 I left at 7.25) ,4 I went 7.300.
Old Nov 30, 2003 | 09:46 PM
97Z-M6's Avatar
so you think i will still need longer pushrods even with the milled heads.
AsianSensation's Avatar
I used this method.
http://www.holley.com/HiOctn/TechSer...ECVTTech1.html
13qtr
Oct 28, 2016 08:11 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
POLOVETTE 94
Aug 21, 2015 07:11 PM
94Form
Jul 17, 2015 10:56 PM
