Shift Point and Rev Limiter for CC503
Old Feb 8, 2007 | 10:03 PM
buzz12586's Avatar
CC503 cam will be going into my car soon and I was wondering what I should change my shift light to. Also I am going to get a tune from MadZ28 and was wondering what I should have the limiter set at??
Thanks.
Old Feb 9, 2007 | 06:46 AM
Chris 96 WS6's Avatar
You don't need to spin it above 6000 rpm, I can tell you that (I have the same Cam). Your power peak is going to be at about 5800rpm. That's with ported heads. On stock heads I'd aim 200 rpm lower to start with.
Old Feb 9, 2007 | 08:17 AM
buzz12586's Avatar
Yea its going to be with stock heads for now. So set the shift light for 6000 and the limiter for 6200-6300. I will have a forged bottom end so it should be ok till there.
Old Feb 9, 2007 | 08:28 AM
chrism400's Avatar
I used the 503 with 1.6 rockers and 1 3/4 Lt's on stock heads. Peak power was at 5800 just like the above poster's was but it remained flat all the way to 6800. I first started with a 6200 shift, and then kept seeing better et's the higher I shifted. I eventually landed on 6600 being the shift point as 11.73 was all she would go. It's all going to depend on your valvesprings as to how high you can spin it. Use good ones like the beehives or, use a dual spring that is set up about 150 on the seat.
Old Feb 9, 2007 | 10:31 AM
buzz12586's Avatar
I do have the beehive springs so maybe I should set the limiter to 6500 or so and shift at 6200-6300???
HarleyZ28
Oct 5, 2015 06:23 AM
cristian1311
Apr 22, 2015 10:20 PM
armedtrigger
Feb 24, 2015 08:30 PM
Nostang 96z
Sep 10, 2002 08:54 PM
Rbain
Sep 4, 2002 12:35 PM
