Shift linkage help
Old Oct 6, 2015 | 03:50 PM
93Z2886's Avatar
Shift linkage help
Stupid question guys. I'm new to this whole ordeal. I've always been a Vw guy. I have a 93 z28 I gotta yank the tranny out of and as of right now am stuck on this damn shift linkage. There a trick to gettin it off or am I just havin a dumbass attack. Any helps appreciated fellas
Old Oct 6, 2015 | 04:12 PM
Re: Shift linkage help
Auto? Just what/where exactly is the problem? You don't give much to go on.
Old Oct 6, 2015 | 05:23 PM
JakeRobb's Avatar
Super Moderator
Well, there is no shift linkage at all on the manual, so I think it must be an auto.
Old Oct 6, 2015 | 09:16 PM
Ya' never know when there is little to no info to go on. The term "linkage" may mean different things to different people.
Old Oct 6, 2015 | 09:49 PM
lt1-xjs's Avatar
There should only be a small bracket for the cable and a nut on the lever. Most important, don't forget to unhook the T/V cable on the throttle body.
Old Oct 6, 2015 | 10:47 PM
93Z2886's Avatar
Right the two bolts on the bottom of the pan for the bracket and the nut on the linkage arm that's stuck. I ended up popping the linkage off the ball (I didn't know that would do that) and yes I meant auto...seeing as how they're
Are no linkages on a manual. I shoulda been more specific but I was in a hurry and didn't realize. But I got the transmission dropped. Thanks for the help
Old Oct 7, 2015 | 10:15 AM
One way to avoid confusion, and avoid having to type the info about your car every time, is to add a "Signature":
https://www.camaroz28.com/forums/lt1...nature-879835/
Magenta_Hearts
Mar 30, 2015 09:42 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
nballisru
Dec 14, 2014 05:01 PM
Jcb890
Sep 9, 2002 11:30 AM
Roshambo
Sep 4, 2002 11:25 AM
