shift light
Old Apr 29, 2004 | 09:07 PM
94TA_LT1's Avatar
shift light
where should i hook up the tach wire?
Old Apr 29, 2004 | 10:32 PM
remaxracer45's Avatar
good question i'd like the answer as well.
Old Apr 29, 2004 | 10:50 PM
Naegash's Avatar
A lot of people wire theres into the ignition coil I know that much. Where exactly into the coil, I'm not so sure.
Old Apr 29, 2004 | 10:55 PM
94formulabz's Avatar
Originally posted by 94formulabz
OBD 1: White wire, red connector on PCM, pin #13
OBD 2 LT1: Same as OBDI PCM * AFAIK
98 LS1: Tach line is Pin 35 on the BLUE connector. Tach line is a white wire
99-00 LS1: Tach line is Pin 10 on the RED connector. Tach line is a white wire
-brent
The switched side of the ignition coil is where you want to pick it up. But i don't see the point of running a wire all over your engine compartment. IMO, much cleaner to pick it up at the PCM locations listed above. And yes, i just quoted myself,
-brent
Old Apr 29, 2004 | 11:29 PM
Pre 96s should be able to use the white/black stripe wire to the coil if you don't want to use the tach wire.
Old Apr 30, 2004 | 04:59 AM
97SS0594's Avatar
i wired my light directly to the coil. worked great!!
Old Apr 30, 2004 | 06:23 AM
12SCNDZ's Avatar
I spliced it into the wire running to my factory tach, in the dash.
Frank
Old Apr 30, 2004 | 06:42 AM
94TA_LT1's Avatar
alright, thanks guys. i will probably just hook to the computer since my wire is coming out the hole right under it.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
MIGHTYMOUSE
Aug 29, 2002 09:18 AM
phantasm99
Aug 28, 2002 11:01 PM
Brady
Jul 29, 2002 10:30 PM
