Shielding power wire from interference (radio)?
Old Jan 28, 2004 | 11:45 PM
96speed's Avatar
I relocated my battery to the rear. The power cable comes right over the speaker wires which creates the most awful "whirring" sound you've ever heard.
Is there anything I can shield the wire with?
TIA,
Ryan
Old Jan 29, 2004 | 12:22 AM
Spllouder's Avatar
u mean the main power wire from ur battery is running over the speaker wires ? is these after market speakers ? where at are these wires crossing ? if possiable croos the wires at 90 degress this will help maybe buy some filters at local auto parts store or radio shack . Or re route some wires. the noise is called alternator noise does the noises pitch change as u accelrated ?
i dont know of any shielding material u can buy try some tin foil i might help give it a try .
Old Jan 29, 2004 | 08:52 PM
96speed's Avatar
Yeah, it is alternator noise (pitch change with revs).
Stock speaker wires.
I was going to try some aluminum tape, but wanted to see if anyone else had any bright ideas .
thanks,
Ryan
Old Jan 29, 2004 | 09:22 PM
Tair's Avatar
re-run the speaker wires. it's really not that difficult at all to just run the wires down the middle of the car. i feel your pain...alternator whine is terrible.
Old Jan 29, 2004 | 09:46 PM
96speed's Avatar
Unhappy
The only re-routing I could do would be to get the power wire out of the cabin before the rear seat.
The power wire comes from the sparetire well over the pass side wheelwell. It makes a 90* turn in front of the rear seat and runs to the driveshaft tunnel, then up to the pass footwell where it exits the car (drilled a hole).
Is there any way to shield it?
Ryan
Old Jan 30, 2004 | 02:37 AM
Spllouder's Avatar
If u want Re route the wires under the car ? what gauge wire ? 4? either runit under ur car with flex lome over the wire . Just a tought .
$hawn
Aug 17, 2002 04:37 PM
rs91
Aug 13, 2002 12:09 PM
kandied91z
Aug 6, 2002 01:18 AM
Matt-01-SS
Aug 2, 2002 04:05 PM
sleeperZ96BT
Jul 24, 2002 11:28 AM
