Shaft mounted rockers?
Old Jan 25, 2004 | 01:42 PM
BottleFedZ28's Avatar
What kind of shaft mounted rockers are available for our LT1s?
Old Jan 25, 2004 | 02:14 PM
$hawn's Avatar
The only ones I know about are t&d machine, you realize that there very expensive like $900.
Old Jan 25, 2004 | 03:47 PM
nd4spd200's Avatar
i run the jesel shaft mount rocker arms. they are like 650 to 700, maybe more.. To me they were worth it.. i needed new rockers when i rebuilt and bigger studs, so i spent a few more hundred and got shaft mount rockers....later
Old Jan 25, 2004 | 11:13 PM
How much more hp do you think the shaft mounted rockers are worth?
Old Jan 25, 2004 | 11:19 PM
Aaronh's Avatar
Shaft mounts are strictly for solid lift cams, correct? Or is that just the recomended application based on cost. My understanding is they reduce valve float, am I correct?
Old Jan 25, 2004 | 11:26 PM
jonaddis84's Avatar
Any increase in valvetrain stability is worth HP, but it all depends on the level you are at. Revving only to 6000 on a hydraulic you arent going to lose much in the rockers, especially if you get a good set of Promags.
On the other hand, if you set yourself up with aftermarket DFI and a solid and spin that bitch to 8grand, you will want a set, there is no decrease in valvefloat persay, since that is all based on spring pressure/rate keeping the valve against the head. It just strenthens the connection between the cam and the valve.
Do a search in advanced, there was a thread about this a week or two ago. some knowledgeable answers to the same question
Old Jan 25, 2004 | 11:29 PM
jonaddis84's Avatar
http://web.camaross.com/forums/showt...hreadid=207006
Found it for ya, BTW crane and I believe comp even started making shafters for SBC, a little cheaper than the TD set
Old Jan 25, 2004 | 11:32 PM
Aaronh's Avatar
thanks bro
Old Jan 26, 2004 | 10:48 AM
kmook's Avatar
Advanced Tech Moderator
I bought and was very displeased with the cheaper Jesel SS (sportsmen) shaftmount rockers. Even though they are advertise to clear large dia solid roller springs, they would not clear mine and i had to overnight a set of pro mags to get the car up and running.
I'd definately go with T&Ds if I were getting a set again. Not only for the reason above but because the people at Jesel were rediculous to deal with.
Old Jan 26, 2004 | 11:31 AM
Gripenfelter's Avatar
I know a local guy with the shaft mounted 1.6 rockers on his SBC. He revs to 6700. He picked up almost 6hp at peak over the Crane Gold 1.6s. He did it mostly for strenth and stability though not for the hp.
Victor Lamb
Aug 26, 2017 02:52 PM
HectorM52
Jul 30, 2017 11:46 AM
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
DirtyDaveW
Mar 15, 2015 07:01 PM
