Severe Stumble after heat soak
Old Sep 30, 2007 | 08:22 PM
Zachz28's Avatar
OK so after i drive the car for about 30 min it begins to stumble. Any time i give it more then 25% throttle it stumbles and almost stalls out. I have cheaked the fuel pressure and it reamins at a 42psi and dosent fall of when i hit the throttle. I used freescan to cheak the MAP MAF and TPS readings and they all respond as they should. I am thinking the ICM may be getting heat soaked and failing. Has any one had any thing like this.
Old Sep 30, 2007 | 09:16 PM
Yes.... heat soak of the ICM is a common problem. That's why Shoebox has a "how to" for spacing it out from the head to minimize the heat soak:
http://shbox.com/1/4th_gen_tech2.html#ICM_cooling
The optical sensor module in the Opti can also cause problems when it heat soaks.
Old Sep 30, 2007 | 09:28 PM
mrseven's Avatar
When my ICM went out, it used to just kill the engine, not make it stumble. It's still a likely culprit though.
Old Oct 1, 2007 | 12:29 AM
Zachz28's Avatar
I still think it may be the icm,however i did the spacer mod almost 2 years ago. Ill test it tommarow
Old Jun 14, 2009 | 05:14 PM
vmatt350's Avatar
What was the fix?
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
9t4lt4z28
Oct 2, 2015 10:28 AM
CARiD
Sep 30, 2015 05:44 AM
damnyankee36
Sep 9, 2015 07:06 PM
