comp guide plates ????
Old Jun 14, 2009 | 01:42 PM
93v8clone's Avatar
i just got my comp guidplates in and on ,all of my rockers are are way off i see it says slight machining is poss but if i make these fit i might as well not run em .is there a better setup?
Old Jun 14, 2009 | 02:09 PM
96capricemgr's Avatar
What misslead you to think the Comp guideplates fit. This is not news atall, very common knowledge.
I went with GMPP guideplates and then when those wore I went with Isky Adjustable.
Old Jun 14, 2009 | 03:31 PM
93v8clone's Avatar
i just ordered a set of the trickflows part #30400623-8 after i searched it a bit
Old Jun 14, 2009 | 07:35 PM
meissen's Avatar
Why doesn't Comp guide plates fit? I've been using mine for about a thousand miles...
Old Jun 14, 2009 | 07:47 PM
raroz28's Avatar
My comp guideplates work fine as well. Which ones are you using?
Old Jun 14, 2009 | 08:18 PM
LT1 valve spacing is different from most other SBCs which causes the rockers not to line up with the valves well. They do contact but are nowhere near straight.
Old Jun 14, 2009 | 08:32 PM
93v8clone's Avatar
thats what was happenin all of my rockers were wide at the tip and narrow at the p/r end like a v
13qtr
Oct 28, 2016 08:11 PM
sh0ckl3y_z28
Oct 3, 2015 06:34 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
NewsBot
Sep 30, 2015 04:20 PM
95blkss
Sep 22, 2015 03:18 PM
