Severe Stumble after heat soak
OK so after i drive the car for about 30 min it begins to stumble. Any time i give it more then 25% throttle it stumbles and almost stalls out. I have cheaked the fuel pressure and it reamins at a 42psi and dosent fall of when i hit the throttle. I used freescan to cheak the MAP MAF and TPS readings and they all respond as they should. I am thinking the ICM may be getting heat soaked and failing. Has any one had any thing like this.
Yes.... heat soak of the ICM is a common problem. That's why Shoebox has a "how to" for spacing it out from the head to minimize the heat soak:
http://shbox.com/1/4th_gen_tech2.html#ICM_cooling
The optical sensor module in the Opti can also cause problems when it heat soaks.
Nayr
Mar 3, 2023 08:34 PM
CARiD
Sep 30, 2015 05:44 AM
