ses what code??
Old Jul 25, 2003 | 12:51 PM
Bobbys_97_Z28's Avatar
Angry ses what code??
now what the heck is this code?? p1371 and what would i check to find out how to fix it?? i do have a slight hesitation...but hopefully this helps! thanx everyone!
Old Jul 25, 2003 | 12:57 PM
P1371 Distributor Ignition (DI) low resolution circuit
Not looking good. It's pointing to your opti. You might want to start by checking the connections of the wiring getting to it.
There is a listing of all codes on my Tech Page.
Old Jul 25, 2003 | 01:05 PM
shoebox
could it just be coil related??
Old Jul 25, 2003 | 01:08 PM
Re: shoebox
Not normally. There are other codes for the coil or ICM. The pcm would only be looking at the opti to set that code.
Old Jul 25, 2003 | 01:41 PM
Hyperspeed97z28's Avatar
Jeez, you got a p1371 and your car is still running?
I popped that code after my car crapped out on me thanksgiving morning. and sure enough.... I had to replace that opti! Good luck bro.. you might get lucky and have a bad connection somewheres but like Rob said, its pointing to your Opti ......
Old Jul 25, 2003 | 01:43 PM
damn
Old Jul 25, 2003 | 01:46 PM
Not unusual to find that as a "stored" code... it seems to set on startup sometimes, when the PCM can't find the signal from the Opti right away. Clear it, and see how soon it comes back.
As Hyperspeed points out, if it was an "active" code, the car wouldn't be running. If the PCM can't find the low res pulse, it shuts down the fuel pump and the injectors.
Old Jul 25, 2003 | 01:52 PM
yeah
yeah i had everything cleared like 1 or 2 days ago...then i keep getting the p1441 code....and when they checked it...it came up with the p1371 also....so now im stumped i mean
Old Jul 25, 2003 | 01:56 PM
yeah
yeah i had everything cleared like 1 or 2 days ago...then i keep getting the p1441 code....and when they checked it...it came up with the p1371 also....so now im stumped i mean it runs strong...except on stop to go...it hes for the 1 sec but it does squeal them....other than that i dont wanna replace it till i kjnow for sure thats what it is
BigED
Jun 23, 2015 07:19 PM
Hannibal
Sep 6, 2002 05:07 AM
lax037
Aug 18, 2002 02:07 PM
91Bird305
Aug 5, 2002 01:39 PM
68 RS
3rd Gen / L98 Engine Tech
Jul 17, 2002 08:57 PM
