SES light, egr valve question
I have an SES light, i took it to auto zone and it showed egr valve. i also have a active recall on my car for the air pump injector or something. could this cause my egr to malfunction? i had the egr replaced once after i bought the car, it was still under warranty. is it an expensive repair?
The EGR and AIR systems are independant of each other. An AIR problem iwll not cause an EGR "code". There are a couple of trouble codes for the EGR - which one did AutoZone get? Did they give you the exact number? Often they give you a "generic" description of what the code means, according to their scanner, and the generic codes are sometime not an accurate description of the problem.
The EGR system could set a code for a faulty EGR solenoid, or another code for a faulty EGR valve. The one for the valve is fairly common in cars with larger exhaust systems and reduced back pressure.
If you need a new EGR valve, I think you can get one for about $35 from the discount guys like Dal or Jason Cromer, and you can change it out yourself. A dealer will charge you $65 for the valve and maybe $75 to install it, and maybe another $75 for "diagnosing" the problem with his scanner.
Get the EXACT code, in the format Pxxxx.
Originally posted by Gary97Z
Where exactly is the egr valve?
that looks hard to reach, how can u tell where the bolts are? is it tough to change out?
there is also a campaign on the EGR valve if it has deteriorated a dealer will replace it no charge; of it was already replaced GM will reimburse it. it is not an official recall. The AIR unit is a recall and will be repaired at no charge. I don't have the GM post cards available but if you fill in prompts at www.alldata.com you should get the correct #'s
good luck
PS
I'll betcha a nickel it's a P0400
good luck
PS
for EGR
Central Office Chevrolet letter CC00096 dated January 2001
"EGR valve may fail due to corrosion of the internal diaphram.
Not a recall campaign
Repair at no charge for vehicle placed in service within 10 years or 100,000 miles
If you have already paid seek reimbursement by writing Chevrolet Motor Division PO Box 33170 Detroit MI 48232-5170 within two years of repair
Any questions call 800-222-1020"
for AIR
Letter C99083 dated October 2000
"Air recall will provide for new AIR pump assembly kit for no charge
Call 800 222 1020 for any questions"
Good luck
for AIR
Good luck
Gtpguy
Jan 26, 2015 04:50 PM
sleeperZ96BT
Jun 5, 2005 09:33 PM
Z28Wilson
Aug 1, 2002 04:27 PM
