Ses Code
You have a problem with the AIR pump... most common problem is a blown fuse. There is actually a factory recall on the AIR pump.
Will not affect perfromance. AIR system only operates for a few minutes at startup. It may cause your radiator fans to run all the time, though.
BigED
Jun 23, 2015 07:19 PM
