"Service Engine Soon", reset and unhook battery?
Old Aug 4, 2007 | 11:46 AM
red_rocket_z's Avatar
I got a Service Engine Soon Light on and I thought I fixed the problem, but all I did was unhooked the battery to clear the computer out after I fixed it, but the light came back on. My question is is unhooking the battery good enough to clear the codes or do I need to take it somewhere and have it hooked up to a computer to clear the codes.
Old Aug 4, 2007 | 12:48 PM
mrmint69's Avatar
Leave it unhooked for a few minutes. 10-30 minutes should do it. I would do that and then take it to a auto parts store and have them read the codes again. I have had several codes at once.
Old Aug 4, 2007 | 01:11 PM
n2ceptor's Avatar
ECM BAT,(93Z) , fuse on driver side panel for 30 seconds and you dont lose radio station/etc.......
If the SES light comes back on, there is still a problem....
Old Aug 4, 2007 | 03:32 PM
Yes.... 30 seconds is all you need. No need to disconnect the battery, and no reason to leave it unhooked for 10-30 minutes.
The PCM BAT fuse is in the end-of-the-dash panel on some years, and in the under hood box on others. Since you didn't tell us anything about your car, no one can give you a detailed answer. Might want to add a "signature" with basic info about your car - year, model, tranny, any major mods. Increases your chances of getting an accurate answer.
If you fix the problem, the light should go off without "resetting". The code will remain stored for a period of time, but will not affect anything.
Old Aug 5, 2007 | 09:46 AM
Thanks guys for the info I will try it again. Car is a 97 z28 with basic bolt ons: TB, cold air kit, pulleys. etc and a 175 shot of nitrous. BTW, code keeps being 420 "bad cataytic converter".
Old Aug 5, 2007 | 09:57 AM
Severous01's Avatar
take it to autozone. do it right...no resetting stations or driver's memory programming in the PCM.
and you'll actually know whats wrong with it.
Old Aug 5, 2007 | 12:05 PM
I wish it was that simple because it isnt. Last year same thing, said bad converter. I replaced the converter and it still said bad converter. It ended up being a wire came loose from the MAS.
Old Aug 6, 2007 | 07:40 AM
Why don't you spend the $40 at Harbor Freight for an OBD-II code reader? Then look the codes up on this list (OBD-II tab at bottom of page):
http://shbox.com/1/Dtcs.htm
or here......
http://service.gm.com/gmspo/mode6/
Old Aug 6, 2007 | 09:28 AM
P0420 Three Way Catalytic Converter (TWC) system low efficiency Bank 1
...doesn't mean "bad converter". It could even be the O2 sensor.
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
97z28k&N
Jan 9, 2015 04:58 AM
Injuneer
Dec 15, 2014 09:36 AM
mspennyhughes
Nov 28, 2014 03:22 PM
slothgrant
Aug 22, 2002 03:01 PM
