Service engine soon light is on?
Old Aug 14, 2006 | 11:36 AM
spedrasr05's Avatar
My service engine soon light is on and when I ran the codes. One said ignition control (IC) module 4x reference too few pulses. The other code that came out was Evaporative emission control system incorrect purge flow.
Does anyone know how to fix this or what it is?
Any info would be appreciative
Old Aug 14, 2006 | 01:12 PM
Re: Service engine soon light is on?
Please post the exact code numbers and some basic info about your car (preferably in a signature). Mind reading is quite difficult.
Old Aug 14, 2006 | 02:13 PM
spedrasr05's Avatar
It is a 97 camaro z28 the codes are P1371 and P0441
Old Aug 14, 2006 | 06:21 PM
P1371 is not loss of 4X signal, its the loss of the low resolution pulse pattern from the Optispark. If the engine is running, its a "stored" code, because if its an active code, the engine will not run. It isn't unusual for this to show up once in a while, but if you clear it and it comes back quickly and frequently, it could be a problem with the Opti of the Opti wiring harness.
P0441 means the flow detector switch on the EVAP lines from the charcoal canister to the EVAP purge solenoid did not detect a vacuum in the system when the EVAP purge solenoid was opened. Could be a solenoid or lines plugged with charcoal, stuck solenoid, broken vacuum line between the flow switch and the purge solenoid, or between the purge solenoid and the throttle body vacuum connection.
I'll repeat what Shoebox suggested - add a "signature" with basic info about your car, so people can answer without asking for the info. You get much better results that way.
Old Aug 15, 2006 | 10:43 PM
yellowjacket01's Avatar
what is the opti? or opti wiring harness im having problems with my car being choppy and missing and every post i see about their cars doing the same its the opti?
Old Aug 15, 2006 | 11:53 PM
It is the distributor.
Old Aug 24, 2006 | 09:48 PM
ShowStopper540's Avatar
a veeeeeeeeeeeeeeeery sensetive distributor located directly beneath your waterpump.
bfmv13trivium
Jan 14, 2015 09:57 AM
97z28k&N
Jan 9, 2015 04:58 AM
Injuneer
Dec 15, 2014 09:36 AM
CaRParts102
Dec 6, 2014 08:45 AM
mspennyhughes
Nov 28, 2014 03:22 PM
