Service Engine Soon Light
Old May 27, 2004 | 09:27 PM
themessageboard's Avatar
I've been having a problem with my 97 trans am ws-6 vert. When push the car a bit i the service engine soon light comes on. I took it to a dealer to check the computer and a code for the catylitic converters went off. I was wondering if you guys think its the actual catylitic or if it would just be an O2 sensor. I think the error code that read in the computer was 141, but im not postive.
Old May 27, 2004 | 11:35 PM
P0141 = Heated Oxygen Sensor (HO2S) heater circuit Bank 1 Sensor 2
That would be the "after-cat" sensor, and its definitely a sensor problem, not a cat problem. You could switch the two after-cat sensors side-to-side... if the code stays on Bank 1 (drivers side), its a wiring problem. If it follows the sensor to bht oehter side, its a sensor problem.
All this assumes you remembered the code correctly.
Old May 30, 2004 | 03:53 AM
Correct Code
The code is actually 0420 Bank1 Catalyst efficiency. Is this the O2 sensors that are before the cats?
Old May 30, 2004 | 11:04 AM
141??? 420????
P0420 is low catalyst efficiency. Either the driver's side cat is "dead" or the after-cat O2 sensor on that side has a problem. Switch the after-cat sensors side-to-side to figure out which, as noted in the post above.
bfmv13trivium
Jan 14, 2015 09:57 AM
97z28k&N
Jan 9, 2015 04:58 AM
Injuneer
Dec 15, 2014 09:36 AM
CaRParts102
Dec 6, 2014 08:45 AM
mspennyhughes
Nov 28, 2014 03:22 PM
