Semi-Cheap 383 Cam Selection Help
Old Sep 1, 2007 | 02:58 AM
WhiteLT1z's Avatar
Ok, so i'm in the process of building a semi-budget minded 383 build.. I bought a CC503 w/ less then 5k on it awhile back for $150 back when I was going to build a stock crank, stock headed 355.. Well plans changed and now I have a fully forged 383 Callies setup w/ slightly ported stock casting(flow #'s below) and am thinking the cam might be too small.. I've got pretty much all the supporting mods(setup below) but i have been out of the game for awhile now so i dont want to overpower myself as this will be the first car with some actual power that I have driven in 5+ years.. I'm waiting to buy a custom grind after I get more seat time with the car and can afford to get the heads re-ported..
So my questions are:
What cam would you guys reccomend that would get me around 7.5's in the 1/8th mile?
Originally Posted by Head Flow Numbers
L ----- I ----- E
.50 -- 253.3 -- 165.8
.55 -- 261 -- 171.2
.60 -- 262.6 -- 175.8
.65 -- 161.8 -- 180.1
.70 -- 161.8 -- 181.3
Originally Posted by My Setup
Mahle Forged Pistons
Compstar Forged H-Beam Rods
Compstar Forged 3.75" Stroke Crankshaft
Ported Heads
918 Beehives
LTCC
Pacesetter LT's and ORY
Borla catback
LT1 Edit
PA Racing Chromoly Tubular K-member
BMR Xbrace and Random Tech TQ arm
300# front springs/ pro-kit rear springs
12 Bolt with spool and 4.10's
SFC, Panhard rod, LCA and relocation brackets
Wolfe Racecraft Rear Swaybar
Front & Rear QA1 12-way Adjustable Shocks
Built 4L60 with 3600 stall
3.5"/8" Weld Draglites
Old Sep 1, 2007 | 07:12 AM
Z-RATED94's Avatar
Why not use what you have for now and see how it runs? Then if you have your heads professionally ported you can pick up a custom cam to match the flow #'s. Maybe you'll get lucky and the heads won't need much work.
Old Sep 1, 2007 | 08:35 AM
ABA383's Avatar
I love 383s because if you set them up right you can have a motor that makes great torque and hp without spinning it to the moon which makes for an outstanding street/strip set up...I'm all about cams with smallish duration (no more than 230 @ .050) and big lifts to .570" with stock ported heads...An off the shelf grind that works very well is the LPE 219/219 .560/.560" on a 112...Most will say that its wayyyy tooo small, but Lingenfelter knew what he was doing...
The 503 is a good cam for duration, but a little shallow on the lift even with 1.6s, but it's not a bad choice either. I run a Joe Overton spec'd custom that in the 220/230 range with .568" lift and its just awesome in my set up...You don't need big gears and big converter if you go with smaller duration and bigger lifts...
--Alan
Old Sep 6, 2007 | 01:05 AM
WhiteLT1z's Avatar
ok, so i guess i'll just stick with the 503 until I get some seat time and get the suspension worked out..
Another question,
I need a new balancer and flywheel so which ones should I get? I want it all internal.
Thanks for ya'lls help guys!
Old Sep 6, 2007 | 02:38 PM
SS MPSTR's Avatar
I think you'll be fairly impressed with the 503. Get everything running right.
Old Sep 6, 2007 | 02:55 PM
Javier97Z28's Avatar
Moderator
c'mon Alan.. give us guys that "spin to the moon" a little credit.. it's alot of fun, even on the street.
Old Sep 6, 2007 | 04:53 PM
30696bird's Avatar
X2!
Old Sep 6, 2007 | 05:55 PM
ABA383's Avatar
I'm not knocking the high revving 350/355 guys...I give you guys tons of credit...Its just not my thing...Javier, your car is badass without a doubt and runs as it should...
My motor has been togther for 12 years and I think part of the reason is the relatively low rpms it sees...I dig smaller cams with bigger lifts and they work well in 383s...
If I can get this thing into the 11.teens at my next track outing and have it do it by only going to 6300 I think that's pretty cool, too..
--Alan
DirtyDaveW
Dec 1, 2016 05:37 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Rde Bandit
Mar 21, 2015 10:17 PM
