Self align rocker juming off valve?
Old Jun 2, 2008 | 07:36 PM
mdacton's Avatar
Any idea what may cause this?
I thought maybe it was too loose but now I am begining to think it may be a bad lifter. I set al valves half turn past zero lash. They are self align gmpp that came with the LT4 kits. The car is a stock bottom ported LT1 heads and 503 compe XE cam. It has PAC behives.
So I pulled the cover off, checked everything put it b ack together started it up and it ticks...pulled cover back off and the same one is really loose again.
Old Jun 2, 2008 | 07:58 PM
MeanGreen97Z's Avatar
Are the tabs still good on the roller? Sometimes they jump over when they get worn down.
Old Jun 2, 2008 | 09:00 PM
mdacton's Avatar
yeah they look fine. I keep losing my lash.....Maybe its just bleeding down. I'm not sure
Old Jun 2, 2008 | 09:06 PM
Jazsun's Avatar
A couple of the tabs on my gmpp's were a little worn. But if thats not the case sounds like a lifter. Nuts not backing down?
Old Jun 2, 2008 | 09:24 PM
You check the edges of the valves? Maybe rounded off?
Old Jun 2, 2008 | 09:28 PM
mdacton's Avatar
brand new. just put the heads on fired it up...bleed the cooling system..drove it about 3/4 a mile. Did not get on it or anything. I am 100% positive I adjusted the valves corectlly. and I double checked them.
The nuts are not backing off. Still tight. the rocker only came off once. I will mess with it more tommorow. Its just a little odd to me. I don't have much confidence in self align rockers.
Old Jun 2, 2008 | 10:08 PM
marshall93z's Avatar
I was advised against using SA rockers with the Beehives. Because you loose a LOT of "self-aligning" room with the way the retainer sets on the valve. Not nearly as deep as stock.
Old Jun 2, 2008 | 10:11 PM
How is the rocker nut still tight if it is coming loose? If it comes off the valve it should loosen up.
oldschool
Feb 9, 2016 09:21 PM
2QUIK6
Jul 15, 2015 07:46 PM
