Failed emmisions, need help
Old May 29, 2008 | 04:38 PM
Romero155's Avatar
Alright so the HC and CO passed with flying colors but my NO(PPM) was really high. At 15mph my NOx measured 863 with a Max of 689 and at 25 mph it measured 1236 with a Max of 706. What causes a high NO reading? Any help would be great
Old May 29, 2008 | 05:09 PM
69gto96z's Avatar
Could be from carbon build-up on the valves.
Old May 29, 2008 | 08:27 PM
Albone's Avatar
The egr system is supposed to reduce nox. Try checking that out make sure nothings clogged or dirty and its operating properly.
Old May 29, 2008 | 10:09 PM
Romero155's Avatar
So i took of the EGR and noticed that there was some carbon buildup blocking the passage on the intake manifold side. I hope that was the problem, is there anyway of testing the EGR to make sure its functioning properly?
Old May 31, 2008 | 04:00 PM
NovaTodd's Avatar
There are a couple of ways. One is to reach back to the valve with the engine running and press the diaphram (sp?) on the valve and see if it changes the idle. The other is to use a small hand held vacum pump and attach to the vacum line going to the EGR vavle. Apply vacum and see if the idle changes. Most likely, if the valve is functioning, the engine will die when you activate the valve (or at the very least will really go down in RPM).
One more sugguestion would be to replace the EGR valve. As old as these cars are at this point, it is just a good idea. (However, that is just my 2 cents)
Old May 31, 2008 | 04:07 PM
Alright so the HC and CO passed with flying colors but my NO(PPM) was really high. At 15mph my CO measured 863 with a Max of 689 and at 25 mph it measured 1236 with a Max of 706. What causes a high NO reading? Any help would be great
Is that a "typo"? Did you really mean NOx measured 863......
Could be running on the lean side, or on the hot side. Both will increase NOx production.
Old Jun 1, 2008 | 05:02 AM
bill122's Avatar
egr test
egr test, get a hand op vacuum pump about 30 bucks at kragen connect it to the EGR hose when you apply vacuum the valve will open and let a lot of exaust gases into the intake manifold the engine should balk and maybe stall if not remove the EGR and clean it it may be sticking. you may also have a bad catalyst talk to a smog guy.
Old Jun 1, 2008 | 12:18 PM
Romero155's Avatar
Yea that was a typo haha sorry, It was my NOx that measured 863
Later on today I will try the EGR test and see if its bad or not. The cat is only a week old so I know that couldnt be the problem. I have also heard that running lean could cause high NOx readings, is that true as well?
Old Jun 2, 2008 | 05:31 AM
.....Could be running on the lean side, or on the hot side. Both will increase NOx production.
..... I have also heard that running lean could cause high NOx readings, is that true as well?
Old Jun 2, 2008 | 11:51 AM
applecorn37's Avatar
Maybe check your catalytic converter(s) too. Could be lots of things. High combustion temperatures cause high NOx numbers also. Maybe youre running too rich.
Old Jun 2, 2008 | 10:36 PM
Running rich will increase HC and CO, while reducing NOx.
Old Jun 2, 2008 | 10:56 PM
neil350's Avatar
You really have to read the results and narrow it down from there, most the guys at the smog places don't know any thing. I would look at what Injuneer is saying and search this board, thats what I did and was able to get my car sorted out.
Jeff1904
Jun 5, 2016 05:00 PM
damnyankee36
Sep 9, 2015 07:06 PM
Boss002
Jul 24, 2015 10:47 AM
Hawk
N2O Tech
10
Feb 3, 2003 02:31 AM
copper88iroc
3rd Gen / L98 Engine Tech
Dec 13, 2002 04:56 PM
