Security light constantly on for 2 years.
Old May 31, 2004 | 10:39 AM
96z's Avatar
96z
My security light has constantly been on for 2 years. I have no trouble starting the car, it never blinks, etc. I have had my VATS disalbed though LT1 edit, will this cause the light?
Should I just take the bulb out?
Old May 31, 2004 | 12:04 PM
You probably had a fault when the engine was already running. The VATS will then allow the car to continue to run and start and the lamp will stay ON (if there is a fault first detected when the engine is being started, then it won't allow it to start). It's probably the key cylinder like the post that was just above this.
http://web.camaross.com/forums/showt...hreadid=267220
You could try to extinguish the lamp by using resistors to simulate the key pellet resistance.
moparman
Mar 5, 2015 08:47 AM
Oncomingstorm22
Jan 22, 2015 07:15 PM
fpete1992
Dec 11, 2014 03:51 PM
blac94Z
Dec 2, 2014 12:09 PM
