security light
Old Sep 6, 2004 | 10:29 AM
apick42's Avatar
security light
I need some help here, i can not remember where but there was a post that
detailed which wire to splice a resitor into for the ignition switch.
light came on while driving the car sunday and on monday the light came on
and as you know the car would not start
Old Sep 6, 2004 | 10:34 AM
Bryan Smith's Avatar
Talking Re: security light
Originally Posted by ponyackn
Is there a write up on how to disable it because my security light has been on for months now? My car has been having trouble firing up. It's an Mg with a new lt4 starter and a new switch behind the clutch pedal was installed a few months back. Now I need to stand on the brake pedal when I push in the clutch to get the car to fire Is this also a security light issue?
Originally Posted by Black6SpdTA
It went off after a few minutes and hasn't been back since. Just to be safe though, how can I disable it?
Thanks for all the help.
http://shbox.com/1/4th_gen_tech2.html#pass_key
http://shbox.com/1/air_bag_disc_2.jpg
Dont make me drop the S bomb.
Old Sep 6, 2004 | 11:23 AM
slopokrodrigez's Avatar
Re: security light
You don't have to splice any wires. Disconnect the plug and stick the resitor leads in the connector side that goes to the PCM not the side that goes up the steering column. Shrink wrap or tape it and you're done. The resistor can be gotten at Radio Shack. The value only needs to be within 10% so don't sweat getting precise. Did mine over a year ago. No problem like before when I changed the steering wheel and the wires got cut. In order to get the airbag light out, had to remove the sir coil. When I did that, I didn't realize the wires from the contacts was rubbing.
moparman
Mar 5, 2015 08:47 AM
Oncomingstorm22
Jan 22, 2015 07:15 PM
fpete1992
Dec 11, 2014 03:51 PM
blac94Z
Dec 2, 2014 12:09 PM
JasonD
Jul 15, 2002 02:17 PM
