search=no hit..opti question
If you get the MSD, you can get the 93/94 opti with the vented cap and hoses. You might be able to just get the vented cap and rotor from them if you want to get a different opti as well. That way you can still use everything you're already using that was listed above.
That is wrong. A stock early cam does not have a large enough hole in the nose of it for the vented opti drive.
chief455, your search should have brought up this link. It is posted almost every time someone asks this question (which is quite often).
http://para.noid.org/~muttvette/opti.html
You would have to get the new diameter of the hole exactly right, since it serves as a pilot hole for the end of the Opti shaft, unlike the unvented set, that supports the end of the Opti driveshaft in the cam sprocket.
Or use reg 93-94 opti with the MSD 95-97 vented cap/rotor?
Depending what I find on my motor - I'd like to avoid the whole cover swap, cam mods etc and just get a good quality opti/cap/rotor on my motor.
You can do either of the options above, AFAIK. Depends on whether you want a whole new opti or just the vented cap. Their 93-94 optis come vented. Call and talk to them or any supporting vendor here. Several carry them.
I am a fan of MSD products - always been great.
I'll figure out which cam/cover I have and buy and MSD opti.
I already have a 6AL box so......
