Seafoam explosion
Old Feb 5, 2007 | 02:16 PM
micfly83's Avatar
Seafoam explosion
So I was seafoaming my car the other day.
My friend was in charge of the gas pedal and keeping the engine at around 2000 rpms while I poured the seafoam into the car.
I was using the typical location, the brake booster hose I believe it is, the hose on the driver side that connects to the black thing.
During the pouring process, I stopped to see how much I had poured (goin for half the bottle). As I did this I put my finger on the vacuum hose to give it some vacuum so the engine wouldn't shut off. When I did this my finger kinda slipped off and the engine sorta died, and my friend gunned it and it when KABOOM, and a big cloud of whitish spray/smoke came out of the hose.
I then said "KILL IT" and that was that.
It turns on and runs fine I think, the idle is a little funky, but has always been like that. (Idles at 1100-900-1000-1100-800-900-1100).
What happened??
Old Feb 5, 2007 | 02:17 PM
96ZCamaro's Avatar
I dont think your car likes that stuff
Old Feb 5, 2007 | 04:10 PM
street demon2k3's Avatar
maybe the engine deiseled for a split second and the smoke was just the burned seafoam? My car would diesel momentarily after I killed the motor by pouring in a lot of seafoam. I got a really big cloud of smoke afterwards and my neighbor thought my car exploded because of all the smoke. if its working bad *** just diregard.
Old Feb 5, 2007 | 04:49 PM
Critter's Avatar
that stuff killed my head gaskets....good luck
Old Feb 5, 2007 | 04:53 PM
DAKMOR's Avatar
Sounds like a bad situation, I doubt that you'll see any problem from it either, there seems to be alot of good to seafoam as I have learned from chats about it.
Old Feb 5, 2007 | 05:07 PM
somebody's Avatar
Here is a good write up on seafoam.
http://www.ls1tech.com/forums/showthread.php?t=534376
Old Feb 5, 2007 | 11:05 PM
Sounds like the liquid buildup in the intake manifold exploded. Might want to check all the vacuum hoses, the MAP and MAF sensors for damage. Check the throttle body blades as well.... they could be bent.
marlar98
Sep 19, 2015 07:53 AM
Anon
Jul 23, 2015 12:18 PM
FieroLT1
Jun 26, 2015 08:43 PM
94GrayV6
Nov 20, 2003 11:22 AM
bad1LEz
Mar 30, 2003 04:48 PM
