Seafoam
Old May 4, 2004 | 03:51 PM
SubsAnDubs's Avatar
Seafoam
I am getting ready to seafoam my car and I heard that it can often damage the o2 sensors. If I pull the sensors will the car still be able to start up? Should the holes be plugged with something?
Also do anyone know how hard it would be access the o2 sensors seeing as everything in the lt1 is hard to access? Where are they located?
Decker
Old May 4, 2004 | 04:19 PM
1msfyter's Avatar
Ive seafoamed 3 times never had a problem,didnt pull the O2's.
Just read the directions and dont suck a lot at once. then drive it good to burn it all off.
Old May 4, 2004 | 05:33 PM
generic's Avatar
If you're going to pull out your O2 sensors to do your seafoam, why not leave them in there, do your seafoam and then replace them with new ones, its always good to have fresh O2 sensors. And yes I also heard that it is good to change your O2 sensors after a seafoam as it tends to push lots of "dirt" through them when you do it that could prematurely ruin them especially if they are already a bit used up and old....
Old May 4, 2004 | 09:57 PM
magnumv8's Avatar
I Seafoamed with the sesnors in and didnt have a problem.
Old May 4, 2004 | 11:16 PM
generic's Avatar
If your o2's are in good condition and relatively new then you should be fine, but if they are old, i would consider replacing them after you do your seafoam :-)
marlar98
Sep 19, 2015 07:53 AM
Anon
Jul 23, 2015 12:18 PM
94GrayV6
Nov 20, 2003 11:22 AM
Marky82
V6 Tech
Apr 13, 2003 02:16 PM
bad1LEz
Mar 30, 2003 04:48 PM
