Scat rod hp rating
Old Jan 19, 2010 | 05:22 AM
  #16
96SSIndeed's Avatar
Originally Posted by Bersaglieri
Define bunch.
If you not going over 750hp, they will be fine.
-Dustin-
going to be a 200-300 shot. more than likely around 250. We'll see what the numbers are on a 200 shot then probably move up to a 250.
Old Jan 19, 2010 | 05:27 AM
  #17
96SSIndeed's Avatar
Originally Posted by 94FormulaLT1
Those Carillo rods he just bought will be more than plenty.
I agree. Next will be a forged crank. If i can't find a callies for a good price i'll just go with a scat. I'm wanting to put really good heads on it and with a nitrous cam make around 420ish to the tires. Then hit it with a 200-300 shot. Not sure if a nitrous specific cam can make that kind of power on motor but i plan to have a little woodpecker smoking a cigar in it if you know what i mean. I'm not too worried about n/a numbers though, this is going to be a nitrous motor, straight up.
Old Jan 19, 2010 | 06:13 AM
  #18
96SSIndeed's Avatar
Also a 383 is a 3.75 stroke crank with 6.0 or 5.7 rods right?
Old Jan 19, 2010 | 07:08 AM
  #19
DirtyDaveW's Avatar
383 = 3.75" stroke x 4.030" bore.
Are you going to use a progressive controller with the N2O? When I was spraying, I used the Jacobs Nitrous Mastermind. It really helped smooth out the delivery. I'm sure there are much better digital controllers out by now.
Sounds like a fun build.
Old Jan 19, 2010 | 09:36 AM
  #20
96SSIndeed's Avatar
so rod length doesn't matter right? the 6" rod will put the pin higher in the ring pack. Shouldn't have to worry about anything with forged pistons. Probably will use some kind of controller. more or less will have in microswitched for wot, and window switched for certain rpm on and off. may just take the whole hit though.
Old Jan 19, 2010 | 09:55 AM
  #21
There is also a 5.85" rod length available. That might be a better choice for a nitrous or forced induction setup, for example, to keep the pin a little lower in the ring pack. Still requires ring rails though. I'm running the 5.85" Oliver Billet rods with a 300-shot.
Old Jan 19, 2010 | 07:40 PM
  #22
96SSIndeed's Avatar
I'm going to have to look into that.
Old Jan 20, 2010 | 03:05 AM
  #23
96SSIndeed's Avatar
Alright, i've found a good deal on both of these cranks and was wondering what would be a better choice for the 383 nitrous build.
http://thunderracing.com/catalog/?ac...vid=4&pcid=119
I'm thinking the Callies would be better for the amount of power 'm looking for. Open to all opinions
Old Jan 20, 2010 | 08:56 AM
  #24
DirtyDaveW's Avatar
You can't go wrong with either of those. I went with an (seemingly) inexpensive forged Scat that cost around $4xx but by the time my machinist balanced it with Mallory Metal it was closer to $700 in total.
Old Jan 20, 2010 | 02:47 PM
  #25
96SSIndeed's Avatar
Thats kinda waht i figured. Thanks
Old Jan 20, 2010 | 10:28 PM
  #26
94FormulaLT1's Avatar
I agree, both of those are awesome cranks. And Scat cranks are known for being underbalanced so the shop usually has to add heavy metal which adds in price fast.
Old Jan 20, 2010 | 11:32 PM
  #27
MachinistOne's Avatar
That's a matter of perspective, they're great if you use really light components which I'm a big proponent of.
Old Jan 21, 2010 | 04:39 PM
  #28
96SSIndeed's Avatar
Yea, it wouldn't be too bad i actually planned on usinf some srp forged lightweight pistons. Added to the fact the rods are 6" it should turn up pretty damn good
93 RedBird
Nov 15, 2015 08:24 AM
football4life
Oct 4, 2015 07:48 AM
Z Power
Sep 19, 2015 11:19 PM
95craz28
11
Sep 12, 2015 07:47 AM
Daluchman1974
Sep 11, 2015 06:12 AM
