scanned codes
Old Mar 1, 2004 | 07:55 PM
SLeeper94Z's Avatar
scanned codes
51 Ecm Prom Error
72 Trans output speed sensor
does anyone know what i can do about these codes what there associated with espically the trans output sensor?
Old Mar 1, 2004 | 08:55 PM
51 may be just a hiccup.
72 is Vehicle Speed Sensor loss (automatic transmission only). Check the connection first.
You may want to reset the PCM and see if either returns.
Old Mar 1, 2004 | 09:26 PM
SLeeper94Z's Avatar
72
would you think trans output speed sensor could make me not shift into 3rd gear like the car is slipping ? is this sensor replaceable , what you happen to have the part #.. thanks
Old Mar 1, 2004 | 10:51 PM
72 is going to affect shifting. The PCM relies on the VSS for making shifts.
GM PART # 8673299 for 94-95 VSS
aj2494
Mar 12, 2015 10:17 PM
Timberwolf
Aug 18, 2002 07:39 PM
91Bird305
3rd Gen / L98 Engine Tech
13
Aug 5, 2002 08:42 PM
91Bird305
Aug 5, 2002 01:39 PM
LT1
Jul 2, 2002 08:27 PM
