scanned codes
51 Ecm Prom Error
72 Trans output speed sensor does anyone know what i can do about these codes what there associated with espically the trans output sensor? |
51 may be just a hiccup.
72 is Vehicle Speed Sensor loss (automatic transmission only). Check the connection first. You may want to reset the PCM and see if either returns. |
72
would you think trans output speed sensor could make me not shift into 3rd gear like the car is slipping ? is this sensor replaceable , what you happen to have the part #.. thanks
72 is going to affect shifting. The PCM relies on the VSS for making shifts.
GM PART # 8673299 for 94-95 VSS |
